Pressed gas pedal, nothing happened. Transmission?
I get that during traction control. I think your traction kicked in. The held the RPM then boom started taking off. That happens when I push my car to the limit. I was once in a lane then I wanted to change my lane then when I punched the gas to accelerate my car's traction kicked in and for 3 - 4 sec it didnt go then it took off like a flying Bat from Hell. Or when I am making a left turn when I push the pedal to hard same scenario traction kicks in. I can see that happening (c320).
This is off topic but I have noticed that most benzes (CL600, my car S500) that when you mash on the pedal the acceleration stinks. I think Benzes like to gently gain speed. My car takes off faster when I hit te gas half way rather than just doing a pedal to the metal.
Edit
Sorry for the long story I tend to make a short story long.
Basically it was probably your traction. If it was your transmission it wouldnt be stuck at 3K it would have reved higher.
Since you were almost at a complete stop and you turned your wheel to one direction then pressed the pedal all the way it probably made your rear tires loose grip thus activation traction control.
MB replaced the throttle position sensor and I never had another occurrence.
The 203 is a drive-by-wire system, rather than a traditional throttle cable. If the pedal sensor goes AWOL, the engine won't respond. Good luck!
This is off topic but I have noticed that most benzes (CL600, my car S500) that when you mash on the pedal the acceleration stinks. I think Benzes like to gently gain speed. My car takes off faster when I hit te gas half way rather than just doing a pedal to the metal.[QUOTE]
+1
Exact same thing happen to me. its the esp kickin' in, i believe ever since ive taken my car out to drag races, the ecu has "learned" and adapted that esp has been going off lately, therefore it just completely shuts off throttle whenever i floor it, then kicks in after a few seconds when it believes there is enough traction.
(it sucks cuz it kills seconds off my 1/4 time!)
