Struts, strut mounts, sway bar end links, bushings
Old May 19, 2009 | 01:21 PM
w.campbell's Avatar
2002 C320 Wagon, 2002 Chrysler 300M
Question Struts, strut mounts, sway bar end links, bushings
I have a 2002 C320 wagon that first started showing front suspension issues through a clunking noise when going over bumps in the front passenger side. It is a very heavy clunk sound, not a light clink or something that sounds like vibration. It sounds like something large and heavy is moving more than it should.
The next symptom was the infamous creaking of a worn strut mount. Opened the hood, grabbed a flashlight, saw cracks in the rubber of the mounts. Definitely more pronounced on the passenger side. Now know for sure that I have to replace the mounts, and plan to do that this weekend. I plan to hold off on ordering struts for now, because they are quite expensive, and I need to avoid that cost for now until I know whether the struts are in bad shape (they don't take returns of course). The car doesn't "float" like a car with bad shocks, so I don't think they are toast.
I have read that the sway bar end links (bushings) have a tendency to wear out, and make a clunking sound over bumps. Anyone else had this problem, or know of another issue that presented with similar symptoms?
Thanks!
Old May 19, 2009 | 03:28 PM
Glyn M Ruck's Avatar
Super Moderator
As you mention. Strut tower rubbers, Sway links & bushes. Another thing to check is castor arm (control/thrust arm) bushes. They are silicone filled & crack & leak. They are a known weakness on these cars and usually fail before anything else.
Old May 19, 2009 | 04:07 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Try tightening up your sway bar end links before replacing them. I had a clunk once and it was because my sway bar end links were slightly loose. Could save ya a few bucks
Old May 19, 2009 | 04:09 PM
dmatre's Avatar
Had: 1987 300TD, Had: 2004 C230 Sport Sedan, Have: 2014 E350 Sport, Have: 2019 S450
Same thing here - check those end links before buying anything!
Old May 19, 2009 | 05:26 PM
w.campbell's Avatar
Great ideas
Thanks for the tips gentlemen - it is much appreciated.
Old May 20, 2009 | 03:04 PM
w.campbell's Avatar
Okay so I checked the nuts on the end links - they were not loose. The bushings on the end links however (those that are on the ball stud at the end that connects to the sway bar) look a little crappy. So I am thinking that I should replace them.
Also, I can twist the control arms about 2 - 3 mm by hand, which isn't a lot, but considering that I can't come anywhere close to exerting the kind of force on them with my hand that the car does when driving, I think I should replace those as well.
Thoughts?
Old May 20, 2009 | 03:19 PM
Super Moderator
Replace the links & castor bushes.
Read this - applies to all C class - Ignore VINs
https://mbworld.org/forums/attachmen...h-bulletin.pdf
Old May 30, 2009 | 01:54 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
found the part # for anyone who's interested. There is only one part # for the lower inner bushing, but there are two part # for the front upper inner bushing which the normal sedans has one and the C32/55 has a different number. This is searched/found through RMEuropean data base. cannot figure out why is there a difference tho.
for all W203
Front lower inner bushing 203-333-09-14
for C230/240/320/350
Front upper inner bushing 203-333-10-14
for C32/55
Front upper inner bushing 203-333-02-14
Old Jun 7, 2009 | 12:53 PM
Bill RHIT's Avatar
2008 Iridium Silver E350 4matic (P2, Pano)
Anyone know how much the dealership charges to replace these? My car squeaks in turns or when going over speed bumps, so I think I might have this problem.
Old Jun 7, 2009 | 05:50 PM
Super Moderator
I cant talk labor rates but the bushes - or bearings as Benz call them are about $20 each.
