C32 AMG Brake Upgrade Discussion Thread
. all u need is bigger wheels to have clearance (just so u know, u'd have harder time finding proper winter tires and cables that'll fit)
If the C32 brakes cause ABS to engage sooner (because the tires would otherwise skid sooner), reduces stopping distance because..... time * speed = distance. Agree?
What's wrong with my logic? The way that I see your theory is correct is when both brakes are so incredibly powerful, that the time for ABS to engage is next to nothing for both. Like in your 1000hp vs. 1500hp analogy....both cars are so powerful anyway.
I agree that stickier tires help A LOT.
1) It is really only relevant in theory, at least as applies to most buyers of "big brakes." Because your point is really only applicable to emergency stops, where you are trying to get from, say, 60 to 0 in the shortest distance. Most buyers of big brakes don't buy for that reason, but buy because they think their car will stop "harder" with bigger brakes. In other words, its not the .0001 second when the brakes are first slammed on in a panic situation that people are really concerned about, and that is the only time period relevant to your point. People buy big brakes because they (erroneously) believe they will stop shorter and harder in everyday, hard street driving - you obviously understand the issues here and I'm sure you will agree that those people are wrong.
2) I highly doubt there would be any difference in the initial panic application, first .0001 seconds. All modern brakes are incredibly strong, and when a car is moving quickly, it doesn't take much, when you slam on the brakes, to get the wheels to break traction and start skidding - I've done it lots of times on the track with non-ABS cars, and at speed takes a lot less force than one might think. I think the 1500 hp / 1000 hp analogy is a good one and applicable in this instance.
Nevertheless, your point deserves kudos because it is the only one in this entire, lengthy thread that at least puts forth a plausible theory as to why bigger brakes might decrease stopping distance. Its one of the few sensible ones amongst a forest of nonsense.
food (brakes) for thought...c/d tests 70-0 mph braking distance:
toyota rav4: 163 ft
ferrari 380 modena f1: 175 mph
wow...so toyota rav4 brakes are better than ferrari brakes right?? :p
Back on topic...you are right about the "on street" performance of big brake kits. If someone enjoyed tracking their car often, I could certainly see why they would want bigger brakes. My Honda Accord saw duty around Palomar Mountain. I was 100% satisfied with the braking distances, but not towards the end of the run. My fluid had boiled causing dramatic fade after coming down the mountain HARD, which made it difficult to keep the car still on downhill slopes when I was done. A cool down period would have helped. Heavy shuttering was the product of either warping or uneven pad wear onto the rotor. These are not MB brakes of course, but if this sounds like you after a day on the track get some motul...a just maybe a big brake kit is worth it to you.
I'm not saying that this happens to all cross-drilled rotors (where did you get this from?)
8-2-2002 10:28AM vadim wrote: [I]Take a look at this first[I]
8-2-2002 11:22AM vadim wrote: No, that's not my car, but it's a MB. I just keep this photo to scare others who believe that cross-drilled rotors are the next best thing after sliced bread. I've heard of things like this happen to them from more than one person.
Big Brake kits, designed properly, WILL make your car stop MUCH BETTER thoughout all aspects of braking. I said that even on normal braking, I noticed myself having to adjust 10 ft back from where I intended on stopping because I was already almost stopped. This is normal braking. I have also found myself behind cars while going 100 mph, and having to slam on the brakes. My car stops VERY QUICKLY. Stock brakes are good, but are nothing close to a Brembo Big Brake kit. The C32 brakes are better than the other C class brakes. Not just in terms of brake fade, but in all aspects of braking. This does not mean that the stock brakes are poor, but there is MUCH to be gained. Why not go and test drive one and find out?
http://www.volvospeed.com/vs_forum/i...=ST&f=2&t=2468
Some dorks think they can cross-drill any rotors, and all will be well.. little do they know...
for those who have done this conversion was it a direct replacement of the parts listed above???
i looked into the AMG factory setup from the C32. from what the parts lady told me. rotors(front/rear), calipers(front/rear), and pads(front/rear) would run about $1600 USD. i'm going to stop by my dealership again today to get actual part numbers. also the diameter of the brembo big brake kit compared to the AMG's is smaller. the brembos are 332 vs. AMG 345.. somewhere around there.. price for brembos' $3300USD vs. ~$1600 USD AMG...
EDIT: Forget the above. I just found an article which confirms the front rotors as being 345mm. http://www.geocities.com/MotorCity/S...50/w203c32.htm
HP RACING .. WHO?
I thought HP made printers?!
If you want aftermarket big... AP, Brembo, and a few other respectable brands that will cost a similar amount.
Ok I have to say one more thing..
How about a detailed set of info on fitting the C32 brakes onto our 'cheap' cars??
P
On the Kleemann page they show their 332mm rotor brakes as requiring 18" wheels. The C32 has 17" wheels and 345mm is 13.58". That doesn't seem like the 345mm brakes will fit under the 17" wheels. Can you confirm the size of the AMG rotors?
EDIT: Forget the above. I just found an article which confirms the front rotors as being 245mm. http://www.geocities.com/MotorCity/S...50/w203c32.htm
