View Poll Results: MB & AMG wheels
AMG
0
0%
OEM MB
0
0%
Voters: 0. You may not vote on this poll
W203/CL203 OEM MB & AMG Wheel Thread - All you want to know
Old Dec 17, 2008 | 06:20 PM
  #226
glocati's Avatar
2016 GLE 350
No problem Dave. The last picture/graphic in Glyn's post really sums it up. The ET (german abbrv. for insertion depth) is the distance of the wheel mounting - hub of wheel from the center line of the wheel. Hub at the center line of the wheel would be a 0 offset wheel. Hub moving out from centerline (as in away from the car) goes into "postitive" offset numbers.
Just occurred to me how clever Centerline wheels' name is...
Those AMG wheels you mention are all in the correct range offset wise for our cars. On sport models, clearing the bigger front brake calipers can sometimes be an issue. Good luck on it and post a pic with the new wheels !
Old Dec 18, 2008 | 01:33 AM
  #227
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by drb930
Thanks Glocati,
I figured it was MM, but i guess the measurement is taken from the center of the rim?
I got some AMG 18" rims, Front are 7.5 ET30 and Rear are 8.5 ET 34.
I know that the AMG 17" are Front ET37 and Rear ET30.
Dave
You are quite correct with your AMG offsets. They will fit your car perfectly & look fabulous.
See Saprissa's thread
https://mbworld.org/forums/c-class-w...de-thread.html
Old Dec 18, 2008 | 09:30 AM
  #228
drb930's Avatar
2005 C230 Sport Coupe
I got brand new Bridgestones 245/35/18 for the rear and plan to mount them up this weekend and put the wheels on. The fronts are at 50% 225/40/18 Conti Sports.
Attached Thumbnails W203/CL203 OEM MB & AMG Wheel Thread - All you want to know-amg-18-wheels.jpg
Old Dec 18, 2008 | 02:32 PM
  #229
Super Moderator
Huh! Chrome - same as Saprissa's - very nice. I love that pattern AMG wheel. So much better than the C32 wheels.
Old Dec 19, 2008 | 03:19 PM
  #230
tevbax's Avatar
04' C230 Sport
Wheel Fitment on a C230 Sport
Afternoon Guys,
Im looking for a set of snows... and had a question. Will a set of SLK320 (03) rims fit on my 04' C230 sport?? The guy thats selling them says that they should fit.... and Tire Rack said the wheels were the same offset and center hole size. Any comments or suggestions??
Thanks!!!!
Mike
Old Dec 19, 2008 | 04:05 PM
  #231
e1000's Avatar
a quarter mile at a time
Are your front brake rotors cross-drilled from the factory? If so, you have a 2004.5 and may have fitment issues.
Old Dec 19, 2008 | 04:13 PM
  #232
tevbax's Avatar
04' C230 Sport
Thanks for the quick reply!!!!! Ill pick them up and update if they actually fit or not.
Thanks!!!!
Mike
Old Dec 20, 2008 | 04:34 AM
  #233
G-NOTE's Avatar
AMG GT-C
Exclamation
those brakes get me very time...
I have looked at alot of wheels I like but don't fit, and everybody says if I use hub centric spacers the wheels will fit, but everybody knows that isn't safe...
Old Dec 20, 2008 | 05:12 AM
  #234
Super Moderator
Good hubcentric spacers are safe - if they can be fitted by Porsche then on our pedestrian Mercs they will be OK. - The reason I would not use them are that so many people have vibration problems with them.
Old Dec 20, 2008 | 05:23 AM
  #235
G-NOTE's Avatar
AMG GT-C
Red face
Yeah I have just heard of nightmare stories where a stud has broken or in our case a lug bolt...
Old Dec 20, 2008 | 01:57 PM
  #236
eurodriver's Avatar
1995 BMW ///M3
I got my C230 wheels a few weeks ago, bolted up perfect, SLK/C230 should use the same offset of about 35-40. Only problem i had was the tires size, ordered it too wide and it was rubbing.
Old Dec 20, 2008 | 02:41 PM
  #237
Super Moderator
You need offsets around 31
Old Dec 21, 2008 | 06:36 PM
  #238
West99's Avatar
W203
I actually think they may fit..
I have to drive 90miles to get them, so I just want to be sure that they really fits.. ?
Old Dec 21, 2008 | 09:07 PM
  #239
glocati's Avatar
2016 GLE 350
The wheels may fit. ( tires are too wide) I have 18x9.5" 35mm ET in the back of my wagon. Running 255/35/18's for tires. No rubbing and i am sitting low on coilovers. It's tight but it works.
My fronts are 18x8" with a 32mm offset so a 8.5" in front with a 30 ET should work. Tire size will be critical in front as well. No guarantees, but i think it may work. Test fit them for sure. Good Luck on it.
Old Dec 22, 2008 | 02:50 AM
  #240
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
they'll fit. you'll need different bolts with bigger head. toss the tires.
Old Dec 22, 2008 | 05:45 AM
  #241
andy_meng1024's Avatar
2003 SL55, 2010 C63
Originally Posted by West99
No not too big, you can easily fit 19inch wheels on W203, but the offset or ET does not fit or are wrong.
Am I right?
So for these AMG wheels/rims I need the 8x18 and 9x18 to fit?
I meant the tires on them were too big.
Old Dec 22, 2008 | 10:07 PM
  #242
glocati's Avatar
2016 GLE 350
We knew what you meant Seeing as you are rocking 9.5" in back yourself !
Old Dec 23, 2008 | 03:42 PM
  #243
West99's Avatar
W203
Thank you very much guys, I think I will give it a try!
Old Feb 9, 2009 | 12:39 PM
  #244
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
Can a stock alloy be fixed?
The bent rim that I have on the front, they are saying it can be fixed. Are they blowing smoke up my tailpipe or is this accurate?
I have been told that you can by the MB dealer and that you cannot by Mr. Tire. Any experiences? Is it going to be tough to balance?
Old Feb 9, 2009 | 12:49 PM
  #245
velvet fog's Avatar
05 SL500, 02 BMW Z3 (Mrs. VF), 05 FJR1300, 91 ZX-11
It can probably be fixed to hold air, but it will probably be out of round forever and vibrate in the 60-70 mph range.
I had one bent like that (not quite as bad) and had it repaired for about $90. The repairing guy said the alloy used was "really nice" and didn't immediately crack like cheaper wheels. It was out of round by ~.025 and I never got it to ride as smoothly as before.
Old Feb 9, 2009 | 01:05 PM
  #246
07 Benz's Avatar
2007 C230 Sport
+1 - I have had a bent rim fixed and it looked good, just never felt the same...
Old Feb 9, 2009 | 01:44 PM
  #247
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
I could sell you one of my stock 2005 wheels. I put the C32 wheels on mine, so I have a set. PM me if interested.
Old Feb 9, 2009 | 02:48 PM
  #248
Sent, thanks
Old Feb 9, 2009 | 03:28 PM
  #249
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Your best bet is to find a replacement.
Check the forums and ebay.
I bought a whole set of rims from a forum member for 50 bucks!
But, one was cracked. I kept 2 to match the 2 I already had, sold one on ebay for $85, and still have the cracked one to be melted down when I get around to it. So basically I got 2 free rims, and all my money back.
Old Feb 9, 2009 | 03:37 PM
  #250
Good call. Yeah, I'm going to stay away from getting this repaired.
