Actual weighting
I'm not sure that unladen weight includes fluids. I've heard it referred to as "dry" weight, possibly meaning no fluids at all. I'm not positive, though. Maybe someone else can chime in.
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
I think the more important question is... What is the air speed velocity of an unladen swallow?
I don't know
NOOOOOOOOOOOOOOOOOOOOoooooooooooooooooooooo....... ..............
Super Moderator
A commercial scale near the 405 & 110 interchange registered 3835 portly C32 pounds with half a tank of fuel, its full-sized spare/sundry tools/consumable liquids - and me aboard.
Should be at least twenty pounds lighter.
Wow, you are missing out on some of the best British comedy ever!!! I highly recommend you look into that.
MBworld Guru
white and whiter
industry standard unladen weight means the car is operational with 5 gallon of gas. usually they use base model with no options.
curb weight is usually with standard features of the car with no options and full tank of gas. C32's curb weight with no spare is around 3540, so we can figure john put in the spare tire that weight about 35-40lbs minus the half tank of gas I'd say a good 15-20lbs? that gives us john's weight around 220lbs? lol
03 g35 coupe...........02 c32 Sold
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
I weighed the C32 a couple weeks ago with only the drivers seat and me in it. Basically gutted. Weight was 3461.
Ok, thanks for your responses, basically where i was getting is, i removed some unnecessary items from my car, and swap some other items in for lighter units, and i will be going to a scale very soon to see how much does the car weights. So far, i noticed that my car seems to be handling a bit better and it doesnt sway in corners as much as when i got it stock
2003 C230K Coupe Orion Blue
I got bored one night on the highway and pulled into a closed truck scale for fun. They conveniently leave the scale display on.
This is a 2003 W203 coupe with no passengers, and a few kg of stuff in the trunk. I didn't look at the fuel gauge.
830kg - front axle
690kg - rear axle
So that's 1520kg curb weight, with a 54.6/45.4 F/R weight distribution.
830kg - front axle
690kg - rear axle
