My HID Install
Rating: Thread Rating: 2 votes, 5.00 average.
Old 08-26-2009, 03:35 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Originally Posted by Gabe007
I'd like to get a 55w as well! Did anyone ever complain about any glare on your low beams?
No complaints. I've driven in front of my own car at night and it's not any worse than other reflector HID-equipped cars. My beam pattern is perfectly stock and I didn't adjust them up or down.
Old 08-28-2009, 10:55 AM
omg its nate's Avatar
06 C230 6 Speed FTW
Originally Posted by eesjunin
See my post on the other forum : http://www.benzworld.org/forums/w203...-6000k-11.html
I installed them right under the lights, nice, clean and out of the way. The only problem you might experience ($$$$) with your drivers side balast is it might fry the electrical components around it. There was a post on benzworld where the kid mounted the balast close to where you have it and it fried ESP control module( i think thats what he fried). Anyways, cost him major mulla to replace that. Just passing this along
here is the posting read: http://www.benzworld.org/forums/w203...tallation.html
Thanks for this info. I will take a look and move it.
Old 08-31-2009, 02:11 AM
aac85's Avatar
2005 c320 4matic
how safe is this ballast location?
i had it for a couple of weeks with no problems.... how close to the esp did that guy place? double-sided tape on the module itself? LOL
Old 08-31-2009, 02:12 AM
LILBENZ230's Avatar
Don't mount your ballast to the ESP module!
Old 08-31-2009, 07:57 AM
eesjunin's Avatar
Nowhere ...Fast
+1^^
the kid had it mounted on the wheel well right next to the module...i would remount it if i was you.
Old 08-31-2009, 09:50 AM
06 C230 6 Speed FTW
I put mine on the other side of the windshield wash fluid, is that far enough away?
Old 08-31-2009, 10:31 AM
  #32
eesjunin's Avatar
Nowhere ...Fast
Meaning between the headlight and the reservoir? The thats sufficicent, i just wouldnt mount it anywhere behind the headlight in that area, since anywhere you mount it is waaay too close to the ESP module
Old 08-31-2009, 10:46 AM
  #33
06 C230 6 Speed FTW
Correct - Thanks
Old 09-01-2009, 01:59 AM
  #34
LAMB09's Avatar
2011 C63 AMG
How come the kit is so cheap? when like an mtec kit is 300 plus? Also is this just a halogen replacement, I ask because I am interested in adding this to my coupe if it is really so cheap and easy to install. I bought some aftermarket H7 bulbs but they just don't do the trick for me.
Old 09-01-2009, 07:38 AM
  #35
eesjunin's Avatar
Nowhere ...Fast
the Kits come in whatever bulb you need...but its plug and play, so eah direct bulb fitment...
The technology has been around for years, to tell you the truth, its just now making its "debut"...so not sure why MTEC's are so expensive
Old 09-01-2009, 05:52 PM
  #36
aissupply's Avatar
CLK 55 AMG
Ballast Mount
What do you think about where I mount the ballast.
You you think it safe, I don't want to burn any thing
Thank you
Old 09-02-2009, 01:02 AM
  #37
Norwichdelta06's Avatar
2007 c230
so nobody asnwered my question why did you have to drll a hole? i thought it was all plug and play?
Old 09-02-2009, 01:09 AM
  #38
Super Moderator
samaritrey's Avatar
THE C350
take a second look at the pics and you will see why you have to drill two holes. and yes it is plug and play you don't have to cut any wires.
Old 09-02-2009, 11:43 AM
  #39
aissupply's Avatar
CLK 55 AMG
ballast mount
can you show me where are you mount your ballast
Thank you
Old 09-02-2009, 01:01 PM
  #40
orateam's Avatar
07' R350
Thank you
Dude, i'm a newbie at these forums, but i'm not on other forums. It's not cool to keep repeating your question on multiple threads daily. Give someone a chance to comment or they'll ignore you forever.
Old 09-02-2009, 01:40 PM
  #41
eesjunin's Avatar
Nowhere ...Fast
Thank you
And where is that?
Thank you
Who are you asking?
If me the see post #25 there is a link to show you, probably, the safest install location
Old 09-02-2009, 03:03 PM
  #42
Super Moderator
samaritrey's Avatar
THE C350
Thank you
first you dont need to ask a question twice. most members on here will respond to you eventuality and if they don't then you made them mad. i am in a good mood today so i will help you out i had a good
it really doesn't matter on the passenger side but drivers side put it as far away from the abs modular as you can. i wedged mine in between the headlight and the windshield washer fluid filler neck. fit perfect and only needed one zip tie to keep it nice and snug. personally i cant stand the look of having the ballasts any where besides the bottom of the headlight. that is why i got the bix off ebay really cheap!
Old 09-02-2009, 04:46 PM
  #43
wvadam's Avatar
C230 COUPE 2003 M271
Originally Posted by aac85
i would advise against the 55w...i just installed mine a couple days ago
REALLLY REALLY bright....nothing wrong with that....but the fact that our cars have halogen beams is not good. mine has a decent cutoff for the beam...but halogen is halogen so there WILL BE UNAVOIDABLE GLARE. probably 35w be the better choice...but running the risk of flickering
do you know what causes this flickering? I just installed a replacement ballast same brand and it is flickering for the first 2-3minutes after startup and driving me crazy!
Old 09-02-2009, 10:20 PM
  #44
aac85's Avatar
2005 c320 4matic
go to the dealership and have XENON=present
that would allow the OBC to accept the lower power since regular halogens operate at 55w...
Old 09-06-2009, 04:19 PM
  #45
Untouchable08's Avatar
2005 C230
After drilling the hole in the cap, how did you fit the bulb through, do you somehow disconnect it from the harness? I don't want to pull it off and break it.
Old 09-06-2009, 04:39 PM
  #46
howardyudoing's Avatar
07 c230 sport
so i had mine in for a whole whopping hour before i took mine out. don't get me wrong i loved the way they look and the way they illuminate the road, but without a proper projector housing, the spread is all over the place, and there is no cut off whatsoever. i was literally blinding everyone and myself when stopping behind someone at a stoplight.
i would advise buying bi-xenon headlights if you were to do hids at all. i just think that without the proper projector housing, the hids are way too distracting to other on the road.
and since i'm one of the few who like how the regular reflector headlights look better than the bi-xenons, i am going to stick with halogens for now.
ps. i love the way the 2004 e class xenon projectors look, i'd totally be content with a retrofit in the normal housing, but too much work at the moment.
Old 09-06-2009, 04:40 PM
  #47
07 c230 sport
you pull the plugs through the hole not the bulb.
Old 09-06-2009, 10:33 PM
  #48
wvadam's Avatar
I had to drill the hole a lot bigger than what they claimed. And it was easiest to put the connector, not the bulb, through the drilled out hole. wedge/force it through.
Old 09-08-2009, 11:59 PM
  #49
jerrynorasing's Avatar
2005 Mercedes c230 Kompressor
I had the same problem and couldnt figure it out after going through 3 hid sets. lolz one i seen a thread about hid, it you need to install litlle capacitors to the ballast they sell them at radio shack. My problem is now FIXED!!
Old 09-09-2009, 12:04 AM
  #50
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
Good for you! Putting a HID in a housing designed for a halogen is against federal vehicle code. Obviously enforcement is poor.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: My HID Install
