3000 Rpm
Your adaptive auto tranny has adjusted to the driver's driving style. You can probably reset it (not sure if disconnecting the battery is the only way) and start driving a bit more aggressively, so the tranny learns that style.
Regarding the engine speed at 80mph, the only way to reduce the revs would be to put in a different rear differential - such as dropping the 3.07 diff from a CLK in place of the 3.23 gears that're back there now. This will likely hurt the overall acceleration, though.
- BT
My C320 Automatic shows 3000 RPM @ 80 mph. It almost feels like it needs another gear. The automatic transmission feels and shifts soft. Is there a shift kit or other mod that will fix this?
You could change your final drive ratio if you want to turn lower RPM on the highway, but it will slightly hamper accelleration.
BTW, 3k at 80 is actually pretty low already.
The C320 is supposed to be a smooth car - it will not shift like a racer (or a C32). I think my car (speedtronic) shifts pretty abruptly at times, in fact.
