P0142 O2 Sensor Bank 1 Sensor 3
Old Dec 18, 2009 | 02:36 PM
raspeed's Avatar
C230
Where is this sensor? I think I can see 1 and 2 .. but 3?
This is an '02 C230K with the 2.3L ...
Old Dec 18, 2009 | 02:42 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Bank 1 in OBD2 talk means the side with cylinder 1. Position 3 seems odd, so I am not sure. But typically the upstream O2 sensors give you issues and not the downstream.
Old Dec 18, 2009 | 02:43 PM
Glyn M Ruck's Avatar
Super Moderator
There is no sensor 3 on the M111 - wierd???
Old Dec 18, 2009 | 04:17 PM
raspeed's Avatar
C230
No I'm just an idiot, I think it's actually P0412 ... doh!
Now how to change the subject.
Old Dec 18, 2009 | 04:51 PM
johnand's Avatar
Super Moderator
P0412 - Secondary Air Injection System Switching Valve A Circuit Malfunction. Sorry can't help on that one, hopefully Glyn will chime in again.
Old Dec 19, 2009 | 02:19 PM
raspeed's Avatar
C230
thanks... we've had pretty variable weather, lots of moisture above and well below freezing
Old Dec 19, 2009 | 04:33 PM
Super Moderator
Hi
See diags - Secondary Air pump & Air injection line & shut off valve 300
You need to troubleshoot this entire arrangement including, air pump, relay & fuse & shut off valve 300 in diagram.
Attached Thumbnails P0142 O2 Sensor Bank 1 Sensor 3-m111-air-pump.gif   P0142 O2 Sensor Bank 1 Sensor 3-m111-air-injection-line-shut-off-valve-300.gif
Old Dec 19, 2009 | 07:45 PM
raspeed's Avatar
C230
Thanks, I will report back!
