B Service Questions.....
Happy New Year
so I'm now 200 miles overdue on my B Service lol.....I called Silver Star MBZ and they said it would be like $270ish. I want to do a ATF flush too, but they said they don't do that on 5 Speeds (only 7). Also, I'm gonna have them look at this: https://mbworld.org/forums/c-class-w...g-harness.html
AND I'm gonna replace the spark plugs. Should that be good? What other stuff should I do as the car nears 80,000 miles?
and Lastly.....does anybody have a place in the LA/San Fernando Valley area where I should take my car to have this done?
Im getting kinda worried as the miles keep adding up, I need this car to last me a few more years at least......so I wanna do all that I can
thanks a ton for your input
btw I called an independent mechanic.....he said like $500 (twice as much as the dealer!!)
You can ask for Jerry Reyes or his brother Arturo Reyes or his other brothers whose name i cannot recall at the moment but also last named Reyes. They've had experience in the MBZ field (Long Beach, Signal Hill, Downtown LA) and all went to school in Chicago for Mercedes Benz Master Tech. Field.
Let them know Chris Gonzalez from Hope Christian Center church sent you.
-Chris
Try Serge @ Hyevon Motors, he's a good honest guy and will take care of your car.
http://www.hyevonmotors.com/
BMW's SAABS MB all have that fill for life or 100,000 except those 7 speeds. But have ou ever change the fluid on one of those vehicles at 50,000? Looks dark in comparison to new fluid. Put it this way it's cheap insurance and it can't hurt to change thr transsmiioon fluid early.
Transmissions is an area where I could use some additional instruction. I was suspicious about running automatic transmission fluid for 150,000 miles because I do know that particulate matter and it's binder (glue) is removed from the clutch disks in normal operation and contaminates the fluid. I questioned some PR guys from Mercedes and they said that the friction material and the fluid was engineered together as a system to give an extended service life. My questions are a) is the fluid sold in the US different than that supplied in the rest of the world? (ROW) b) is the friction material different in the US transmissions?
If they are the same, I think I need to change my fluid! I am at 105,000 miles which has been reached with only the replacement of the water pump at 50,000 miles.
Your advice about the fuel filter is sage also. Thanks for all your great input to the forum. I appreciate it very much.
