Need a little help with my exhaust
Old Feb 14, 2010 | 08:27 PM
Smallbodybenz's Avatar
2002 c230 coupe
I noticed my exhaust leaking and it sounded as if it was right under my driver seat. So i assumed it may be the Donut gasket between the exhaust and manifold. I got everything off but the only thing i see is a beveled gasket type thing attached to the manifold. I pried at it with a screwdriver but im not getting anywhere with it.. i came to conclusion that is attached to the manifold itself.. What im trying to ask is Is there a gasket of some sort between the exhauist pipe and manifold? Or do i need to keep trying to get the beveled looking gastket off the manifold even know it looks like its apart of it?
Old Feb 15, 2010 | 05:18 AM
Glyn M Ruck's Avatar
Super Moderator
M111 or M271 engine?
Old Feb 15, 2010 | 10:26 PM
2002 c230 coupe
shoot idk haha i have a 2002 c230 coupe but i think its the m271
Old Feb 15, 2010 | 11:19 PM
samaritrey's Avatar
Super Moderator
THE C350
where are you located?
Old Feb 15, 2010 | 11:43 PM
2002 c230 coupe
ok so i guess its the m111.. i learned something But i am located in central Indiana
Old Feb 15, 2010 | 11:55 PM
samaritrey's Avatar
Super Moderator
THE C350
ok so USA so i think you are correct.
Old Feb 16, 2010 | 07:28 AM
Super Moderator
Surprising - No seal ring shown at the manifold - only at the center of the exhaust. I see 2 different configuration manifolds have been fitted to the M111.
Attached Thumbnails Need a little help with my exhaust-m111-exhaust.gif   Need a little help with my exhaust-m111-exhaust-manifold.gif
Old Feb 16, 2010 | 11:55 AM
2002 c230 coupe
I was looking for that diagram online but couldnt find it so kudos to you! But im stumped now , what do i do if there is no gasket made or even present for it? Cause i dont know what else it can be and its the only thing that make sense..
And My exhaust is # 20 on the diagram.. Single pipe going to one inlet to the manifold
Old Feb 16, 2010 | 12:10 PM
2002 c230 coupe
Also this THREAD ON BENZWORLD explains what is happening pretty welll.. Maybe this will help you better understand
http://www.benzworld.org/forums/w203...ting-cold.html
Old Feb 16, 2010 | 12:30 PM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
Do you see a "trail" of black soot indicating that exhaust is leaking past this joint? Generally, the gasketless joints are pretty good at sealing unless they come apart and then get corroded, or they somehow warp. I have gasketless ball/socket joints on my header collectors of my Monte, and they are very good.
One trick you can do, if you can get under the car with it running (safely, of course) is to take a piece of tissue, and hold it around the joints. When it starts to flutter, as if in the wind, you have found your leak. If you are checking near the engine, you may have to unplug the radiator fans to prevent them from interfering.
If it's an audible sound you are chasing primarily, you can narrow it down by taking a piece of 2-3 foot long, 3/4" diameter heater hose (available at any autoparts store) and hold one end to your ear. With the other end, fish it around any suspected areas for the source of the noise. You can usually pinpoint the source rather easily like this.
Old Feb 16, 2010 | 12:37 PM
2002 c230 coupe
Those are some good ideas thank you.. I will be trying that either today or tomorrow.. Although i am pretty certain its coming from the exhaust / manifold... This willl let me no for sure tho
Old Feb 16, 2010 | 04:57 PM
Super Moderator
6 buck Chinese auto stethoscope from Kragens/PartsAmerica or similar
Old Feb 16, 2010 | 06:19 PM
LinDenKid's Avatar
C230 coupe 2002
I used to think the same thing, till i realized everybody's m111 engines, sound like a lawn mower! Make sure you check and confirm that you have a leak.
Old Feb 17, 2010 | 12:27 AM
2002 c230 coupe
I hope not cause it really bugs me!! I took it to the shop today and they found no leak at all... They told me that i need a tune up because it sounds like it echoing .. I changed the plugs and coil packs already ,what else would anybody recommend ?
Im still kind of determined that it has a leak cause im not completely dumb when it comes to cars... maybe im just hard headed haha ..
Old Feb 17, 2010 | 05:45 AM
Super Moderator
I presume they checked the center exhaust joint. You might have a loose baffle or broken piece of Cat honeycomb in the exhaust. Are all exhaust heat shields firmly in place & nothing touching? Is the rear gearbox mount in good order?
The M111 is a very strong engine but a little rough which is why they designed the M271 after too many complaints.
Old Feb 17, 2010 | 09:52 AM
2002 c230 coupe
i guess that will be my next step in diagnosis, now that i think about it i have a bad feeling that it is my CAT . If that is the case i guess i will be looking into some money or just dealing with it.. I did just buy this car so i am trying to get the little kinks out of it as i am perfectionist when it comes to my cars.. Thanks for the advice GLYN M RUCK
