OH BEE DEE
Old Mar 2, 2010 | 07:39 PM
danev6972's Avatar
2003 C240
OH BEE DEE
Hey all,
Bought this scanner
http://cgi.ebay.com/ebaymotors/Profe...item5190d6ad15
Plugged it in earlier and somehow: READ has failed. Verify the connection at the DLC. Verify the ignition key is ON. Played with it a few times with the same outcome
Tried it with my wife's kia & worked perfectly.
Any thoughts? Thanks.
Dont think this unit is updatable.
Found this STFF but I'm still out of answers.
https://mbworld.org/forums/c-class-w...er-issues.html
Old Mar 2, 2010 | 10:57 PM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
Originally Posted by danev6972
Hey all,
Bought this scanner
I have the exact same unit from the same seller. Works like a charm on my car. Re-check the connections (its really hard to connect and needs a bit of force before it will connect properly). If that doesn't work, your OBD connector on your car is pooched.
The scanner is 100% compatible with our cars.
Old Mar 3, 2010 | 05:36 AM
Glyn M Ruck's Avatar
Super Moderator
That's a great little scanner - should work fine
Old Mar 3, 2010 | 07:07 PM
danev6972's Avatar
2003 C240
What if it's "pooched"?
Is it an expensive replacement?
Is there a data link fuse?
Seller offered me $20 for any inconvenience.
Old Mar 3, 2010 | 07:54 PM
jcnash's Avatar
Depending on which part of your connector needs to be replaced, it can get pretty expensive. Usually these are pretty fool-proof ie...you have to try very hard to break the OBD connector.
As a first step, I would recommend getting under the dash (facing up) with a bright flashlight and just looking at the connector. I have a feeling youll find one of the pin connectors is blocked or bent. Try blowing compressed air into it if you dont find anything.
Then try re-connecting the scanner and like I said earlier, you have to use some force. My scanner wont connect and read until I kinda wiggle the connector around and use some force to push it in.
Not sure if there is an independent fuse for the OBD connector. There is however a fuse map floating around the forum...just do a search for fuse map and read through the list to see if any one fuse controls the connector...but I doubt it.
And yeh..the seller is a great guy! Sells a quality product + great service.
Old May 5, 2010 | 07:17 PM
danev6972's Avatar
2003 C240
Did what you said...blew compressed air into it, wiggled it,...and still not reading.
I was looking at it with the flashlight and nothing bent as far as i can tell. Now do all the "holes" in the connector have contact points in them? Looks like gold when you shine them w/ a flashlight. I see a few holes missing them...don't know if that is the way it should be. Thanks for your time.
Old May 5, 2010 | 07:26 PM
skittles's Avatar
Moped
oh snap.... your passed the 30 day money back guarantee......... maybe you just got unlucky and got a bad one..
Old May 5, 2010 | 07:39 PM
danev6972's Avatar
2003 C240
The scanner actually works on my wife's Kia sorento. I think it's just my car.
Old May 5, 2010 | 09:35 PM
contact148's Avatar
2003 c240 4matic wagon
go to a local parts shop some of them will scan your car for free with thier obd2 reader if thiers works on your car it will tell you your cars fine
Old May 6, 2010 | 05:55 PM
PharmD's Avatar
2006 C230 Sport
I'd probably try that as well, or try it with a buddy's. At least that will identify that it may just be some strange incompatibility between your particular car and the scanner (albeit inexplicable) and not an issue with your car itself.
Old May 6, 2010 | 11:36 PM
jcnash's Avatar
Not sure if all the holes are supposed to have connectors..Ill check during the weekend and get back to ya.
Meanwhile definitely try what the others have suggested...try a buddies scanner or the auto parts score scanner on your car...
Old Jan 7, 2011 | 09:06 PM
danev6972's Avatar
2003 C240
While I was in autozone I borrowed their scanner. And viola! it worked.
It was a bad scanner. At least it was not the car.
