HELP!!! Fog Lights Malfunctioning
So I was playing with DAS and did a setting and now when I make a turn my fog light turns on and then off. WTF is going on? This is what I did.
This is a DIY on how to enable Cornering Fogs on your 203. The first time I saw these were on a 204 and I honestly thought the fogs were malfunctioning until my friend told me it's a feature. We have always had this feature but it was never enabled.
Also if your DAS menu doesn't have this let me know and we can do it through Developer Mode
Happy Cornering,
Karo
From what I've read if you have the OEM w203 active fog lights you get a different fog light lens that throws a far wider beam off to the side. I had a rental Israeli-spec Honda Civic awhile back with Xenon lights and the wider beam fog lights and they made a big difference in turns at lower speeds.
So far I haven't been able to find the wider fog light lenses in the ETK.
https://mbworld.org/forums/c-class-w...t-foglamp.html
I do know other models absolutely had this feature, one that I remember off the top of my head is the CLS. Yes it looks like one fog light is out when you're using it. I don't think it's very functional however.
Eric is right, the luxury 203's had these enabled with lighting package.
From the mid-cycle change guide;
Outside Lighting – Cornering Fog Lamp
• Cornering Fog Lamp is an additional light function realized with
special fog lights (61° versus 21° reflector, H7 55 Watt bulb)
• Fog light on the inside of the turn is activated under specific steering
angle or turn signal requests
• Inverse activation if reverse gear is engaged
• Fog light is activated dependant on
– Turn signal activation
– Steering wheel angle
– Vehicle Speed
– Reverse gear
• Soft dim activation and deactivation
• All functions related to this feature are controlled by SAM-Driver
à Not a version coding, unique SAM-Driver
