Rough Idle On C240 *Please Help*
How long to I see any results from this, and what else should I have checked?
If anyone knows it would be greatly appreciated its driving me insane.
Here are some possible causes that may pertain to you, though. Mine idles rough, too.
Motor or tranny mounts, spark plug wires, gunk (techron takes helps care of it)...
injector cleaner will take a tank or so to work
Make sure that MAF & throttle body are clean.
I really need some help no one seems to be able to diagnose this problem because the car is not throwing a code out. Please
There is no reason whatsoever that you needed to post a duplicate thread. It's nigh on impossible to diagnose a car on a message forum, especially one that doesn't have a code. Why don't you try another mechanic that isn't clueless about the car? That's MY suggestion about the car. My suggestion about the forum is not to post multiple threads about the same thing as I'm pretty sure it is against the rules, and if it isn't, then it is certainly not good forum etiquette.
whats up with the noobs having attitudes here recently matt?
just say you don’t have a dam clue
