Mugenx Depo FX-R retro thread
Old 04-21-2010, 10:07 AM
  #51
03MBC320's Avatar
2003 C320 4Matic
beautiful beam pattern, if mike could turn this into a DIY on what exactly he did to the headlight thatd be amazing
great work guys, way to fix the problem about Depos!!
and i really like that inside ring being yellow, nicely done
Old 04-21-2010, 03:43 PM
  #52
Mu9enx's Avatar
01' C32o
Thanks for the responses guys. I am absolutely in love all over again with the car! I can see so much better, and everything just looks OEM and Mercedes like. It took a lot of pain, blood, sweat, tears, and work, but it turned out a LOT better than I could imagine. Ran into a couple of issues with the projector and cheap plastic headlight, but we got it to work through perseverance. If I could only get a nice DSLR shot; point/click cameras just don't do the lights justice! If you're in Socal and want to check it out for yourself, it'll be even better. There's so much blue and purple, it amazed me. Alas, the headlight lens with the glare lines kill a lot of the color and intensity, but it is still badass. Maybe in the future I'll get some Sonar headlight lens (they don't have glare lines) and put it on; it'll totally pwn OEM BiX easy. The high beams work like a charm, and they ARE the ISHT. I don't know how a regular OEM 203 BiX high beam cutoff is, but mine is simply amazing. My friends tell me that I'm literally a wall of light in front of them, and it's aimed just right where I don't blind people badly, .
A DIY for this would be kinda complicated, as each headlight/projector requires different things. Like on the Depos, shroud cutting is definitely needed, along with tweaking of the FX projectors. I could only have done this with Mike's help; his experience made this project smooth sailing. What I suggest would to be visit HIDplanet.com and go through the forums researching. Like with the DEPO's, you need a projector that is small enough so that you won't need to modify the headlights as much. You're limited in options because the way the headlight is. There is absolutely no way I would be able to fit TSX/TL/S2k projectors with out heavy modifications to the chrome cover. But with other brands of headlights like the Eagle Eyes or Sonars, there is a larger choice of options because there is no visible shroud. If I don't make sense, I'm sorry, I'm not the type that would be able to explain very well, but i believe that researching is fundamental, and HIDPlanet or other forums would help in that regard.
Old 04-23-2010, 07:28 AM
  #53
lancemb's Avatar
03 c240
awesome mod man! your car is coming along very nicely! you have definitely left me in the dust....
cool, now you can help me with this retrofit right tommy? =]
Old 08-17-2010, 01:06 PM
  #54
Javvy's Avatar
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
impressed with your effort and work man, the cutoff is superb and the Hgh beam is out of this world man......definately looking forward to do this mod..........
Old 08-17-2010, 01:07 PM
  #55
Javvy's Avatar
If I had seen this thread before I would not installed my New Depos would have hacked it and put in the FX-R's........but now will have to wait for the right time to do this....
Old 08-17-2010, 08:25 PM
  #56
Mu9enx's Avatar
01' C32o
Yeah bro, you should definitely consiter doing this. It might be a bit of work, and you might be out of a car for a bit, but this will definitely help you out with visibility and safety. And boy does it look so good!
Old 08-17-2010, 09:43 PM
  #57
d1no's Avatar
05 c230k 6spd
awesome job guys.. when i get some time Im going to retro the e55 projectors and mod them to produce a bit more color and also use 55 watt kit so it should be decent.. im only using the e55s because i got them for a nice deal last year
Old 08-17-2010, 10:21 PM
  #58
Mu9enx's Avatar
01' C32o
YEah, E55's are pretty cheap nowadays. You basically get Bix for less than 1/3 of the price, haha
Old 08-17-2010, 11:42 PM
  #59
d1no's Avatar
05 c230k 6spd
lol i got mine for $70 or so shipped from istanbul .. the depo projectors cost me like 240 brand new and a ddm 55w hid kit with D2s bulbs is like another 70 so for a bit over 380 i will have real Bix and it will perform better than stock
Old 08-18-2010, 08:08 AM
  #60
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
i dont know if its exactly a e55 replica in terms of measurements, but from the looks of it. It looks like it would be a direct swap pretty much. There better hid projectors out there, but the e55's would be superior then any projector you would get in a aftermarket head light.
Old 08-18-2010, 11:30 AM
  #61
fookoo303's Avatar
2003 c240
If the projector in the depo is the same projector in the eagle eyes than its dimensions are completely different than an e55. the e55 is a 3 inch and the projector in the eagle eyes are a 2.5.
Old 08-18-2010, 11:31 AM
  #62
TemjinX2's Avatar
there different...i'll try to measure it when i have some time.
Old 08-18-2010, 11:33 AM
  #63
fookoo303's Avatar
2003 c240
oh ok. I've worked on the e55 so i might be able to tell you if the dimensions are the same if you can get me a pic of the depo projector.
Old 08-18-2010, 12:43 PM
  #64
Javvy's Avatar
what glue do you use to reseal the lights...any links of where to buy them from........the only part that scares me is using the heat guy to remove the clear lense, I am scared that I might burn it up......is there a special trick or some thing that one should follow. I mean heat a portion and them use a screw driver or some thing to seperate that portion of the lense form the housing. Some direction would be helpfull..............I AM NOT THROWING MY DEPOS IN THE OVEN for sure I will bake them, plus it will be difficult to remove the complete lense quickly before the hoursing starts to cool down............any thoughts..........
Old 08-18-2010, 01:27 PM
  #65
fookoo303's Avatar
2003 c240
you wont burn the lens. i put my headlights in the oven at 250 degrees for 10 min or so to melt the glue. I have put plenty of headlights in the oven to melt the glue and it's never damaged it as long as you make sure you put a towel underneath the headlight and you dont have any part of the headlight touching the metal inside the oven.
Use nissan sealant to put the lens back on.
http://www.mynismo.com/products/?id=5577&rsku=0 ]
Old 08-18-2010, 04:17 PM
  #66
Javvy's Avatar
fookoo303.......woudn't the towel burn or catch fire???...and for the sealer do I need 2 packs of it or juts one would suffice???...after looking at Mu9enx's cut off and work......I am all charged up..............hehehee
Old 08-18-2010, 04:26 PM
  #67
fookoo303's Avatar
2003 c240
the towel wont set fire, it might get slightly browned on the bottom from touching the metal grill in the oven but that's all. You only need one roll of sealant. There's enough in that roll for maybe 4 headlights. If you dont take off the old sealant then you just need to lay a thin layer of the new sealant on there. It wont need much since there's already a good amount in the assembly.
I can send you a DIY on baking the lights if you want, pm me your email. It's a DIY for an rsx but the procedure is pretty much the same. oh yea and the time and temperature can vary slightly.
Old 09-14-2010, 06:39 PM
  #68
I_C_Class's Avatar
W204 C350 4matic Coupe, W203 C320 4matic, W212 E550 4matic
this is coool
Old 09-15-2010, 07:47 AM
  #69
Super Moderator
Glyn M Ruck's Avatar
Have not been watching this thread. Many PMs to answer
Great job guys. OEMs are quite hard to impove on but you've done it in spades.
Old 09-26-2010, 06:13 AM
  #70
rock26's Avatar
mecendes c230
Brought the same headlight and projectors you got. Will work on this project with my free time off.
Old 09-26-2010, 09:42 PM
  #71
TemjinX2's Avatar
good luck...post pics.
Old 09-27-2010, 08:30 AM
  #72
Javvy's Avatar
good thinking rock26...............I have my deops installed and now I have the FX-r projectors sitting in my garage and I am dreading the fact that I will have to do the labor twice................man it sucks.........or I can buy another set of deops install the FX-R's on that & install them on my ride. And then work on the other set install another set of FX-R and sell it here..........dont know man.......really not worth the time unless some one is really intrested in buying them......... I mean depos are like $350 (With HID) FX-R $150....then labor............
Old 09-27-2010, 01:29 PM
  #73
d1no's Avatar
05 c230k 6spd
I assume you still have your OEM lights? I would just reinstall those and work on the depos as time permits. They are not that hard to take apart you just have to be careful not to break anything as they are on the flimsy side. I was able to retro the e55 projectors in my depos in under an hour once they were taken apart and it looks oem like it came that way.. I will post pics of my entire setup once I finish.. I pretty much rebuilt the Depos with oem gears for the leveling all the flimsy stuff replaced with oem and my hid ballast will be bolted on the bottom of the headlights just like oem that will be easy to disconnect incase of replacement .
On a side note dont the e55 projectors come standard on Rovers and Maximas and just.. The color on those is pretty awesome to me when they are coming behind me
Old 09-27-2010, 01:46 PM
  #74
TemjinX2's Avatar
Yeah i think your correct the older maximas and rovers had the e55 projectors as well. There actually hella projectors, but people just call them e55 projectors, probably because they first appeared on the e55.
The newer maximas use stanley like in the g35 and tsx.
So you were able to confirm that the e55 projector is bolt on to the depo?
It would be a cheap upgrade to real HID projectors since you can buy e55 projectors for less then $100.
Old 10-01-2010, 02:08 AM
  #75
rock26's Avatar
mecendes c230
Hey TemjinX2
Did Mugen have to cut the reflector housing to fit the fx-r projector into the mounting holes?
I can't seem to fit the fx-r projector into the mounting holes or less I cut some of the reflector housing down or trim it.
Quick Reply: Mugenx Depo FX-R retro thread
