Rear wheel bearing how too???
anyways has anyone here done the rear wheel bearing on a 2003 c240 4matic?? wagon
I ordered the service manual DVD last week from Mercedes but with 2 days of ice on the roads I figure my package is going to get delayed.
I ended up getting it all covered but if its 4matic you need a special puller
I did find a new post on a UK forum from November where a guy did detail that the bearing is pressed on the inner and outer races (he was also replacing the rear backing plate, his due to rust through). He said he removed all the links to the knuckle to put the entire knuckle in a press. Then the bearing ended up falling apart after removal, so a new one is required on each side as well.
I think I'm going to make a small cut in my new plates and bend the heck out of it until I get it to slide into place. I really don't want to risk something going wrong with the links/axles/bearings/differential.
