Down shift, check engine light, V8 grumble, power loss, and a burning smell. (20 sec)
Old Jul 17, 2010 | 04:56 AM
  #101
Glyn M Ruck's Avatar
Super Moderator
Lane - Then put things on hold.
Please do me a favour. Run two tanks of fuel back to back with Techron concentrate. We might have a dirty injector here.
Old Jul 17, 2010 | 04:57 AM
  #102
laneshift's Avatar
C240
Will do. This may end up with a happy ending after all!
Old Jul 17, 2010 | 07:38 AM
  #103
laneshift's Avatar
C240
I just came back from filling up, adding a healthy dose of techron.
On my drive, everything made great sense. Perhaps, since my car wasn't driven for two or so weeks, cylinder four's injector became partially clogged, returning my misfires. I guess the injector wasn't very clean to begin with when the misfires before I left came along.
Results to follow. I'm making many trips today!
Old Jul 17, 2010 | 08:23 PM
  #104
laneshift's Avatar
C240
Two more cylinder four misfires after 50 miles of spirited driving. Perhaps cylinder four's injector(s) shouldn't be pushed just yet.
Old Jul 17, 2010 | 08:34 PM
  #105
Super Moderator
Run through 2 tanks of fuel & see what happens otherwise it's back to the list above. Injector deposits take a little while to remove.
Old Jul 17, 2010 | 08:51 PM
  #106
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
or it could be the injector simple needs to be replaced...
I had a issue with throttle position sensor glitch two nights ago, so don't feel too bad. lol
start the car, puts it in reverse back out the garage and driveway, puts it in drive, notice no power, figure it is a tranny slip from not grabbing the gear since it has happened before, down-shift, waited, and go, and 10ft later the engine just shuts off.....
restart the car, throttle blips by itself as if it's gasping for air between idle and 1200rpm, restarted couple more times and back to norm.
no error codes...although i do think my fuel pump is possibly dying which is the only conclusion i can come up with for that symptom.
Old Jul 17, 2010 | 11:01 PM
  #107
laneshift's Avatar
C240
Are injectors hard to replace?
Old Jul 17, 2010 | 11:19 PM
  #108
Super Moderator
Lane - an injector is not hard to replace but at your mileage it is way below injector cycle life - more likely dirty from crap American fuel - & it is crap because you guys want it cheap - same as SA. If we all ran Euro fuel we would have no trouble.
Let's try & clean injectors first. 2 tanks with Techron concentrate will take the injector back to as new clean. If it then gives crap then maybe replace.
Long before then - you have not answered when last your car had a fuel filter & before we mess with fuel pumps we need a fuel rail pressure test.
Old Jul 17, 2010 | 11:45 PM
  #109
laneshift's Avatar
C240
I have never replaced it. I bought the car at 56k miles. Should I replace it for good measure?
And what can explain the 50 miles of trouble free wide open throttle spirited driving, and then misfires to follow later? It baffles me!
Old Jul 18, 2010 | 12:26 PM
  #110
laneshift's Avatar
C240
Here's a pic of the a cylinder four plug. I took both out, the other seemed normal. Second one of cylinder four seems a bit dirty, or maybe I'm just not a pro reader of spark plugs. Did I not give enough torque to the plug, perhaps?
Old Jul 18, 2010 | 12:51 PM
  #111
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
You are due for fuel filter replacement. It is due every 65K miles/5 years. Mtnman posted a great DIY on it.
Old Jul 18, 2010 | 03:42 PM
  #112
laneshift's Avatar
C240
Thanks! Will do. This will keep my injectors cleaner?
Old Jul 18, 2010 | 07:52 PM
  #113
Super Moderator
Lane - I really need to see the tips of the plugs from the combustion chamber end. Looking back up the internal insulator with the firing tip dead centre,
Like this
From what I can see at the moment things look OK but I can't read the plug properly.
Attached Thumbnails Down shift, check engine light, V8 grumble, power loss, and a burning smell. (20 sec)-impp_1005_11_o-10_maintenance_tips-good_spark_plug.jpg
Old Jul 18, 2010 | 07:57 PM
  #114
Super Moderator
A new fuel filter will ensure proper fuel rail pressure at the injectors & give your fuel pump an easier time. This will help ensure that all injectors provide the correct amount of fuel. No 4 injector might be slighly clogged & with low fuel pressure we have a misfire when you place demand on the engine.
Old Jul 18, 2010 | 11:33 PM
  #115
laneshift's Avatar
C240
Thanks for that information. I've been wanting to know! Also, I'll have a spark plug picture that is taken right as soon as I get a moment.
Again, thanks for being such a supportive bunch!
Old Jul 19, 2010 | 04:13 AM
  #116
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Now you really should feel better....my tps just took a dump...and I'm 7 mile from home with hills in the way.....
Old Jul 19, 2010 | 08:40 AM
  #117
laneshift's Avatar
C240
Good god! Hope you get home safely and get your car running healthy again soon!
Old Jul 22, 2010 | 10:14 AM
  #118
laneshift's Avatar
C240
One tank of techron treated 93 octane fuel down. I'm weary of going past 4k rpms. I got three misfires in a row doing that. I had to shut off the engine, stop at the side of the road, and restart, every time, or the grumbling noise and power loss would persist.
Old Jul 22, 2010 | 11:52 AM
  #119
Super Moderator
This does not make me happy but we will go back to the list until we fix this thing!
Old Jul 22, 2010 | 04:43 PM
  #120
laneshift's Avatar
C240
P0304 is the only code I get one after the other.
The low grumble noise is basically the engine bogging down. Power is lost. The car must be restarted to regain power and the noise goes away. If it's still confusing to understand, I can take a video.
Car starts fine. Upon startup, there is no pop pop pop from the exhaust, it's smooth. When the car is fully warmed up, it's only slightly choppier.
I'm getting a loud, loud belt whine. Sounds like I have an unmuffled kompressor. Sounds cool, though will it cause problems?
Thank ya.
Old Jul 22, 2010 | 06:07 PM
  #121
Super Moderator
There is no doubt that the car is triggering limp mode when you throw a P0304. You must get that filter changed & maybe, because it is cheap we should change the plug wires on cylinder 4. I hate throwing parts at cars without proper diagnosis but the dealer does have an advantage because they can try things with lots of spares around. I'm suspicious of your CPS as well but it almost always causes hard starting which you don't have.
That loud belt whine is the tensioner pulley. If it really pisses you off change it. They all go sooner or later & have been improved.
Old Jul 22, 2010 | 07:18 PM
  #122
laneshift's Avatar
C240
The plugs and plug wires were changed with oem bosch plugs and wires from the dealer. Plug wires weren't cheap at the dealer, but I was in a hurry. Remember? After I changed those, my car was problem free until I let it sit for two weeks.
That fuel filter does not seem like a fun job. Oh well, what must be done, must be done.
Old Jul 22, 2010 | 07:28 PM
  #123
laneshift's Avatar
C240
Glyn, also, is it safe for the engine to drive in limp mode? I find often times that limp mode kicks in, I'm doing 50 down a busy road and can't always pull over safely.
Old Jul 22, 2010 | 09:12 PM
  #124
Super Moderator
Sorry - did not realise you had done wires.
Yes it's safe to drive in limp mode. It's done to protect things.
The filter is not too bad to do with your capability. If that does not help we had better get that compression test done & maybe we are heading for an injector. We can do that but there is a chance it will be money wasted.
Old Jul 22, 2010 | 09:30 PM
  #125
laneshift's Avatar
C240
So to save money, do the fuel filter first, right?
This is where I get confused. If I have poor fuel pressure, wouldn't all my injectors be causing misfires?
Or is the techron all part of the scheme? We're cleaning out injector four, while giving back maximum fuel pressure, which should cancel out the misfires, correct?
Lastly, if the injector is just faulty, we'll replace that.
Is that the correct road to take?
Thanks!
Edit: Also, can someone please explain limp mode to me a bit more? My car is terribly choppy and sounds absolutely horrid when limp mode kicks in. I guess that's regular?
