CLK63/Black parts fit W203 and CL203
Old Jun 13, 2010 | 01:53 AM
hkirov's Avatar
C230 Kompressor Coupe
Hi there guys,
I am working on a CLC project, i am actually trying to build the fastest C Coupe , well still working on it.
So here it is i wave various parts which are from different years and models MB Cars fitted on mine , most direct fit and some with modifications.
So about the CLK63/Black , well you can use lots of their parts to improve your w203 and cl203 , the reg CLK63 ones are easier to fit but the Black needs to get dirty because it has lots of E and CLS parts in it.
1. Big brakes : CLK63 reg brakes front and rear fit with no modifications, you have 6 piston front and 4 piston rear, front rotor is 355mm stock but you can get the 380mm as it will fit, for the price go to parts.com , front set up is about 2000$ and rear 1300$ and its all oem parts.
--later will post the part numbers for you.
CLK63 Black , rears are the same but fronts are same as CLS so you need to replace a lot, front wheel bearings control arms and so on, and they don't come cheep but the brake set for the front is cheaper the amg ones will cost you 1500$.
--later will post all the different part #.
2.Sway bars : they fit and guess what way cheaper than H&R.
3. more to came soon
Old Jun 13, 2010 | 09:05 AM
Milkm4n's Avatar
2006 c230
wow this is epic
Old Jun 13, 2010 | 09:08 AM
dynomite05's Avatar
04 CLK 320 > CLK32K
Any part #'s for the sway bars?
Old Jun 13, 2010 | 12:59 PM
hkirov's Avatar
Sway Bars
OK guys here are the part # :
Rear
A2093260365 - for the Black
A2093260165 - for the Regular
A2033261281 - boot for the Regular and you need 2
A2033260881 - boot for the Black and you need 2
Front
A2093200410 - for Black and Regular
A2033270090 - boot for it and you need 2
Attached Thumbnails CLK63/Black parts fit W203 and CL203-black-1.jpg   CLK63/Black parts fit W203 and CL203-black-2.jpg
Old Jun 13, 2010 | 01:01 PM
M-bENZ's Avatar
Corrolla
Any chance the part number for the airbox ?
Andy
Old Jun 13, 2010 | 01:15 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Andy
+1, and the part #'s for the rear brakes, if you don't mind sharing.
Old Jun 13, 2010 | 01:20 PM
hkirov's Avatar
Andy
Yes i can give you the part number but i don't think it will fit as the M112 and M156 don't share same set up for it but you can give it a try. if you want let me know i will post picture and all the parts you need to do it.
I cant tell will it work or no, cause M112 and M156 are not the same you have to try and let us know.
Old Jun 13, 2010 | 01:23 PM
hkirov's Avatar
I dont mind M8ts, will share all i know just ask, and sorry if i cant post right a way but may not have time, so give me a while and will do it
M-bENZ's Avatar
Corrolla
I have M113 = CLK 500
M112 = CLK 320
Andy
Old Jun 13, 2010 | 01:29 PM
hkirov's Avatar
M112 = CLK 320
Andy
sorry M113, but M112 and M113 share same air box set up.
Old Jun 13, 2010 | 01:33 PM
hkirov's Avatar
Rear Brackes
here they are :
- A0034202983 - Caliper Left
- A0034203083 - Caliper Right
- A0054204120 - Brake Pads set
- A1714230212 - Rotors you need 2
same for Black and Reg CLK63
Attached Thumbnails CLK63/Black parts fit W203 and CL203-black-3.jpg
Old Jun 13, 2010 | 02:03 PM
M-bENZ's Avatar
Corrolla
ur correct on that and the only difference is the front cover is abit shorter compare to M112. Anyway, please share if you can.
Thanks,
Andy
Old Jun 13, 2010 | 02:13 PM
hkirov's Avatar
OK M8, will post all the parts you need as well as all nuts and bolts and clamps and so on and picture on it, just give it some time cause i have to go out now and wont have time, but will post later today.
Old Jun 13, 2010 | 02:28 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
here they are :
Thank You!
Old Jun 13, 2010 | 02:46 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Cool thread
I believe there are a few forum members who have the clk63 front strut bar, but I dont have access to the part numbers. Maybe someone can post the part numbers on that.
Old Jun 13, 2010 | 02:51 PM
hkirov's Avatar
Sway Bar = Strut Bar
Originally Posted by TruTaing
Cool thread
hi there M8 look up the beginning and you will see the part numbers for it under Sway Bars.
Old Jun 13, 2010 | 03:35 PM
timmynabenz's Avatar
2006 C230 SS, 2006 S500, 2008 CLS550 Lorinser
this is pure win
thank you hkirov!
Old Jun 13, 2010 | 08:53 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
specs for the CLK sway bar would be nice. if they're different than the ones on the CLK55.
Old Jun 14, 2010 | 02:32 AM
hkirov's Avatar
OK so EPC shows :
-- for the CLK55 front Sway bar there are four part numbers depending on the year of production:
A2093230065 - 23mm, and replaced after by A2093230165, witch i think has 23mm.
A2033233165 - 22mm, and replaced after by A2033234165, witch also has 22mm.
-- for the CLK63/Black there is no info but i assume they are 25mm or 26mm, as the biggest it can fit with the newer boots is 26mm as H&R ones witch i have in the front.
Old Jun 14, 2010 | 02:46 AM
hkirov's Avatar
CLK 63/Black AIR Box
Thanks,
Andy
OK M8, i had no time to post all part numbers but here it is pics on all of them so you can read, will post the parts later one by one.
Attached Thumbnails CLK63/Black parts fit W203 and CL203-black-4.jpg   CLK63/Black parts fit W203 and CL203-black-5.jpg
Old Jun 14, 2010 | 02:49 AM
hkirov's Avatar
Great Rims LOL
Originally Posted by timmynabenz
this is pure win
thank you hkirov!
man those rims are killing
Old Jun 14, 2010 | 04:51 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
OK so EPC shows :
if they are the same size and cheaper then it would be a good deal. if not then H&R or Eibach would still be a better upgrade probably.
Old Jun 14, 2010 | 12:12 PM
hkirov's Avatar
I doubt the CLK63/Black ones are smaller from the H&R and Eibach, lets not forget that they put all Performance parts in them and the suspeniton stok into the black is coil over similar to the KW V3 Inox one witch is the best there is.
Old Jun 14, 2010 | 12:34 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
If you don't know, just say so. No reason to try to pull logic out of your ***.
The C32/55 is supposed to be "performance" too, and they're much smaller on those models, so I wouldn't take anything for granted.
Old Jun 14, 2010 | 12:45 PM
badblackbenz550's Avatar
benzo larenzo
i would love some BS clk63 parts on my clk550 =D
