slider above cup holder broken help ?
I'd start with getting a new one.
I've answered this question a couple of times; do a search, and you should be able to come up with the right procedure.
02 c230k coupe
alright thank you
do you order this from the dealer or can you find it online ??
also what is the part actually called, so i can start searching ?
I have no idea what it is officially called. Do a search for the glovebox swap write-up I did; I discussed it there. It's a pretty simple procedure; remove the trim from around the shift boot, then lift up the center console piece that goes around the shifter by lifting up at the front of it, near the ashtray, then tilt the ciggy lighter assembly forward, then you'll be able to slide that whole piece you broke out from the forward part; do reverse with new sliding cover, and you're done.
Kurupt - here's my DIY thread:
https://mbworld.org/forums/c-class-w...r-armrest.html
FYI - easiest way to find a thread from someone is to get them from the member list, then select the "find all threads started by user" option.
02 c230k coupe
DIY - Removal of Armrest (and reinstall of 2-way opening later armrest)
