DIYing service A, have some questions
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
Hi Guys,
So, my service A is coming up in like 16dys and I am planning to DIY it.![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
This is what I have planned to do.
Change oil using Mityvac using 0W40 Mobil 1
Replace the air Filter using the posted DIY
Replace the Cabin Filter.
Check all fluid levels.
BTW have alreday bought all the OEM stock that I would need from europeanparts.com
Is there any thing else that I should change/replace/topoff. If I am missing any thing please let me know.![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
If there is a thread already that has covered this please post a link and I will close this thread. My searches did not reveal anything.
Thankx in Advance for your help.![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Thank you
Javvy
Thank you
Javvy
Javvy you're perfectly fine bro. The only thing I would add is Brake Fluid Flush if you haven't done so already and Transmission Oil and Filter change.
Fuel filter is at 65k (next service) and 91k is Sparkplugs and Coolant is 143k (no worries on that).
I say Transmission Oil and Filter change would be the most important.
13,000 miles Service A
26,000 miles Service B, replace brake fluid, check suspension/body structure, check body for paint damage
39,000 miles Service A, Replace transmission oil and filter
52,000 miles Service B, check driveshaft flex discs, replace engine air filter, replace brake fluid, check suspension/body structure, check body for paint damage
65,000 miles Service A, replace fuel filter, service tilt/sliding roof
78,000 miles Service B, replace brake fluid, check suspension/body structure, check body for paint damage
91,000 miles Service A, replace spark plugs
104,000 miles Service B, check driveshaft flex discs, replace engine air filter, replace brake fluid, check suspension/body structure, check body for paint damage
117,000 mile Service A
130,000 miles Service B, replace fuel filter, service tilt/sliding roof, replace brake fluid, check suspension/body structure, check body for paint damage
143,000 miles Service A, replace coolant
156,000 miles Service B, replace engine air filter, replace brake fluid, check suspension/body structure, check body for paint damage
169,000 miles Service A
182,000 miles Service B, replace spark plugs, replace brake fluid, check suspension/body structure, check body for paint damage
195,000 miles Service A, replace fuel filter, service tilt/sliding roof
https://mbworld.org/forums/3524045-post1.html
04 CLK 320 > CLK32K
Hi Guys,
Thank you
Javvy
Thank you
Javvy
Javvy, check out parts.com they usually are the cheapest for OEM stuff
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Just do the standard service plus at your mileage.
- Flush brake fluid every 2 years - you could leave this till your B comes up.
- You really should do a transmission fluid & filter change if it has never been done. +1 Karo
thankx every one for all your help........I was leaning towards a Tranny oil change as well, but should I do the mity vac suck and top off, or should I drop the pan replace filter inside(I guess thats where ths filter is) and change tranny oil..........I know I will not be able to get to the oil trapped in the radiator line.........but I will get to most of it........any suggestion.......
thankx karo for the detailed break down of the service interval.........
Super Moderator
Javvy - You need to pull the pan to change the filter & flush the cooler lines. You can't really flush the TC.
Does your 4Matic have the 722.6 5 speed or 722.9 7 speed? 5 Speed I think - Yes? The 7 speed has no dipstick tube.
Let us know & we will find the method - Also see DIY consolidated thread in stickies
https://mbworld.org/forums/attachmen...ter-change.pdf
Super Moderator
2007 C230SS; 2014 ML350 BT
"have the 722.6 5 speed or 722.9 7 speed"...........
I have no idea is there a specific place that I should look up this information...........I am screwed if I dont have a tranny dip stick...dropping the pan is a big PIA.........and then filling it up is another PIA..............but if I have too I will......... thanks Glyn for the DIY........lemme check the engine bay and see if I have a tranny dip stick........will report back....
Read my post here: https://mbworld.org/forums/3668015-post34.html for info on how to service the 722.9 transmission. If all goes well and I don't get sidetracked again, I will have a DIY write-up done next week.
holy shiet..........dame........that is sure a PIA now........
johnand, please do I will await your DIY and hold off on doing the tranny oil change. I think I use my Mity vac to pump the tranny fluid using the tool you mentioned will have read up on the mityvac that I have..........
Please don't get side tracked this time and please do the DIY..........and take tons of pictures.........lol
Thankx
Javvy
Thankx
Javvy
Super Moderator
John - thanks for clarification. In SA there was a delay in fitting 4Matic W203's with 7G.
Super Moderator
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
so that means that I have a dip stick for the tranny oil..........???????????
I performed my transmission fluid change at the dealer around 35,000 miles. The transmission is something that gets overlooked all the time, make sure you do the transmission fluid!
Super Moderator
