excessive wear outer edge of front tires???
https://www.getmercedesparts.com/oem...des-parts.html
or is it these?
Did the fluted bolts help in reducing the front outer tire wear? You also mentioned a camber kit...what camber kit are you refering to? Was this camber kit for the rear?
I've lowered my S203 wagon about 1.7 in front and 1.0 in the rear with a H&R Cup Kit. The rears are wearing on the inside due to the negative camber induced with lowering it, but the fronts are still wearing on the outer edges...thought lowering it would even it out, but no.
if you put new tires on it you should see improvement.
I think the only way to correct the rears are adjustable upper camber arms, right? Do you know of a good source for these?
the bolts will help the front, i still see a bit of more wear on the edges due to the way our tires behave when turning etc, but it is much better than before and the wear is barely noticeable...
I went in for Service B with 18K miles on my C300. Service adviser talked me into a 4wheel alignment, but after few hours he called me and said the alignment was so off, that I need a new alignment bolt (this time with grooves) to meet the specs. W T F . . my car never hit a pothole nor go offroad. Stinking bolt is not covered by warranty. Anyone has the same problem. My bill from them afterward is another issue.
