LCD Replacement - European Maker / Supplier
Old Aug 15, 2010 | 11:11 PM
  #101
fookoo303's Avatar
2003 c240
Originally Posted by Glyn M Ruck
The orange screen is an LCD. With voltage applied selectively it goes black & just allows light through the open pixels which will always be orange. Backlight intensity will effect how bright the orange is & LCD voltage will effect how black the black is. If the backlight is too bright it will cause light leak through the black. Achieving pitch black has always been an issue with LCDs - Which is why top active matrix LCD TVs like the Sony XBR8 use dynamic local dimming LEDs behind the LCD panel to achieve high contrast & decent blacks.
the screen itself is actually blue. The problem with putting white light through the lcd is that the color comes out blue. I have already taken it apart and changed the led's behind it and they are bi-color smd with orange as the primary and red as the secondary(for the warnings). I could actually be able to change it to any other color but white since the lcd itself isn't clear.
Also, finding a bi-color smd in white/red or blue/red is very hard to do so my efforts were wasted. I could change all the numbers to light up white, since those are single colored smd's, but I am to scared to mess with the needles calibration.
edit: the led's i also used for the lcd were way to bright and just completely leaked light through the lcd.
Old Aug 16, 2010 | 08:16 AM
  #102
Glyn M Ruck's Avatar
Super Moderator
Thanks - As I said I've never pulled one apart. Right - so it achieves it's colour by the correct spectrum of colours for orange. For a low definition display it's quite sophisticated. Bi colour LED backlit! Wow. Only the German's - I don't know why they did not go the whole way with RGB backlight.
Edit: So in it's unexcited state the OE display is blue? Dark blue?
Old Aug 16, 2010 | 10:52 AM
  #103
fookoo303's Avatar
2003 c240
Yea its pretty dark, almost purple. I would've done the white lights but blue lighting really hurts my eyes so i kept the orange.
Old Aug 23, 2010 | 02:42 AM
  #104
04mbc230's Avatar
2006 C230 Sedan
Alright guys. I think my investigations will end with the following picture.
It has hit about 90 degrees today and my ongoing investigation that results in driving over 3 weeks has already completed. I am going to end this 1 week earlier, since I don't see any reason why I should continue with this. If my other 10 testee has something to update, then it's up to them. It has also racked up over 1000 miles and has been in the cold and heat. As of current, I don't notice a bump or hickup on this lcd screen that is installed.
I will consider this as a success on my part(installation). For those who are intersted in getting the supplier info. Please PM me or the other testees.
Don't ask why the dial is at 72mph. Hint.. i was driving.
Attached Thumbnails LCD Replacement - European Maker / Supplier-0822101618-01.jpg
Old Aug 23, 2010 | 08:35 AM
  #105
Super Moderator
fookoo - Only saw it happen for the first time this weekend - now I understand the bi colour LED backlight - Did not close the trunk lid properly & the whole display lit up in Red.
Old Aug 23, 2010 | 12:20 PM
  #106
mleskovar's Avatar
'17 Jaguar XF
Here's a pic of mine. Heat doesn't affect it. So far my feeling is it's fine and I won't have the contrast biased. I'm still waiting to drive it at night for an extended period before I make up my mind.
Attached Thumbnails LCD Replacement - European Maker / Supplier-lcd-002.jpg
Old Aug 23, 2010 | 12:24 PM
  #107
04mbc230's Avatar
2006 C230 Sedan
Thanks Mleskovar. Your input is greatly appreciated and useful. I am looking forward to the other 9 testers with their results.
Old Aug 25, 2010 | 02:48 PM
  #108
rdisney's Avatar
2004 C230K Coupe
Any updates from the other 9?
Thanks,
Ron.
Old Sep 10, 2010 | 06:17 PM
  #109
Vomit's Avatar
2002 C32 Black/Charcoal
Mine is golden so far. 10 days, hot weather, no problems.
Old Sep 13, 2010 | 03:05 PM
  #110
///AMG4EVER's Avatar
CLS55 Designo 030
Reporting here... Mine is working fine, however there is a little bit of shade vertically on the left portion of the screen...
Anyone else has experience this?
Old Sep 13, 2010 | 03:47 PM
  #111
04mbc230's Avatar
2006 C230 Sedan
Yup. I have that issue too. That is not the LCD related. It's the LED that is failing. Mine has this problem when it's cold. After the car runs for a while it turns back on.
I think a few posts up, I had reported this issue.
I don't think this is an easy fix. You might have to do some soldering on the thin plastic cluster panel to install new LEDs. It looks complicated and not fool proof. I wouldn't touch it if you have no expereince in soldering.
Old Sep 13, 2010 | 04:39 PM
  #112
CLS55 Designo 030
Thank you for the reply.
I can live with it. I just wanted to double check with the group.
Old Sep 13, 2010 | 05:01 PM
  #113
fookoo303's Avatar
2003 c240
yea one of the led's in the column doesnt have a good connection on the printed board. It's an easy fix if your comfortable soldering or brave enough to try.
Old Sep 13, 2010 | 05:05 PM
  #114
04mbc230's Avatar
2006 C230 Sedan
Haha..
Easy for you to say, since you are an electrical engineer student.
As for us noobs, I will say shy away from it. Since this is a sensative piece of equipment you don't want to fry. I mean try.
Old Sep 30, 2010 | 11:06 PM
  #115
jwcaldera's Avatar
c320
Can someone send me or tell me who the european manufacturer is? I would like to order one of these replacement screen!!!
Old Sep 30, 2010 | 11:10 PM
  #116
WaveyKat's Avatar
Something Slow
i installed mines last weekend so far its GREAT :-)...
Old Dec 19, 2010 | 09:19 PM
  #117
xnagra's Avatar
c320
can anyone give the info of where in europe to order this screen
Old Dec 19, 2010 | 09:55 PM
  #118
04mbc230's Avatar
2006 C230 Sedan
Xnagra, I think I had replied to your PM earlier. Check your inbox.
Old Dec 19, 2010 | 11:21 PM
  #119
xnagra's Avatar
c320
i checked my inbox but all that is there is a link with no info on where to order if u did send it can you send me the info again thanx in advance
Old Dec 19, 2010 | 11:29 PM
  #120
04mbc230's Avatar
2006 C230 Sedan
I had just PM you. All the info is there and I had just check the link and it should bring you to the product page. From there you have to select the product. If you read the message, it will tell you which one.
Old Dec 20, 2010 | 02:58 PM
  #121
xnagra's Avatar
c320
thanx alot for ur help i finally got it im ordering tommorrow thanx again
Old Jan 9, 2011 | 07:05 PM
  #122
azizi's Avatar
2002 MB C240
Can anyone PM or release the information for this fix? I just got my C240 a week ago and it has this problem. Thanks!
Old Jan 26, 2011 | 03:03 PM
  #123
neilpilot's Avatar
2016 GLC300 4MATIC
I'd also like oder info on the replacement LCD, please
Old Jan 26, 2011 | 05:31 PM
  #124
04mbc230's Avatar
2006 C230 Sedan
I just PM you with the info.
Old Feb 5, 2011 | 09:58 AM
  #125
neilpilot's Avatar
2016 GLC300 4MATIC
Thank you 04bmc230
Part was received 3 days after I ordered it, and was able to replace in under 30 minutes thanks to https://mbworld.org/forums/c-class-w...placement.html. Didn't bother with a bent wire; just inserted a stiff wire 2.5" into slot, heard click and pulled each end of cluster free of clip. Display looks and works just like the old LCD, but when Memphis summer arrives I expect I will now be able to see display (old LCD was totally unreadible in hot weather).
