Brake Pad Wear Visit Shop/ESP Malfunction/ABS Malfunction/Gauge Cluster Malfunction??
Start the car pop the e-brake up usually and then I get in the display
1. Brake Pad Wear Visit Workshop
2. ABS Malfunction (and the orange abs light comes on
3. Gauge cluster malfunction (speedometer stops working)
4. Steering gets super mega heavy like its not assisted at all at any speed.
5.Sometimes I get ESP Malfunction
Odd part is usually if I turn the car off and then back on, it clears it, steering goes back to normal, and the gauge cluster (speedo) works just fine. I know however it becoming more and more prevalent when i start the car, its happening more and more and will need to be fixed.
To me it would sound like a wheel speed sensor is bad, and specifically the one that reports the speed to the dash which is why the speedo dies with it, and I dont know if its coincidence, or not that the brake pad wear light is on, Ive owned the car since 31k, and never have touched the car besides service B and an oil change last week.
Any idea what it could be, Id like to think a wheel speed sensor or something of the like.
Its a M272 V6, 6MT manual C230 and if it matters, I always use the ebrake to keep the car in place, I dont leave it in gear.
Thanks for any help and insight!
No do nuts done in my car, just driven normally and daily.
Also the power steering is fine, after I re-set the car, and the lights all go away, but Im equally stumped as to why it co insides with the brake issues VIA ESP and ABS
Some times, the most cost/time effective way of resolving complicated problems is to take the vehicle to professional for diagnostics. You'll have to judicate which problem warrants professional diagnostics and which problem can be mitigated by on-line suggestions.
good luck.
Haven’t you participated in sanctioned closed course events? Seem to recall some threads where you claimed to be getting after it.
Most any warranty is null and void after having done so.
Drive mine like an old fart most of the time.
Should it break after occasionally beating the snot out of it, I simply pay the piper for my tomfoolery.
I don't get why the aftermarket warrantee would not cover this. If not, is it worth anything?
It hasnt happened in the past 4 days, which is odd. It has rained a ton, here so I am assuming the rain, has something to do with it, like causing a short when its wet, but It happens well after rain as well.
The car should be storing codes ??
Im assuming there is a sticky about rebooting? or is that simply turning the car all the way off then on? And yes from what MB Sar says when she checked, there where no codes stored, and it happened 3 days before it went in, and was started without the issue occuring maybe 7 times or so between the last time it happened and when it went into the dealer, isnt there something with 5 good starts of the car clears the codes, or is that not true with MBs?
