Camber bolts on all 4 wheels?
2002 Mercedes Benz C230 Coupe
Are camber bolts necessary to adjust the camber on our cars (stock suspension and wheels), or is it only to adjust camber for lowered cars?
Also, are camber bolts needed on all 4 wheels or only the front 2?
Thanks Frank.
So you're saying the bolts are needed for corrections more than +/- 1 degree. Anything less than that can be done without the bolts??
The reason I ask is because before I installed the control arms, the car was obviously aligned and without Camber bolts. So I don't understand why I need them now...lol.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
For front if you have no fluted bolts you really can't do any castor or camber adjustment. You can steal a little bit but not much. Benz is just being cheap not fitting them standard.
Camber eccentrics front end 2 per side if needed.
Rears require camber links or K mac bushings and only if dropped.
If not dropped and rears are wearing tires poorly you have worn or bent suspension items.
Front eccentric bolts can be needed even if not dropped if the wear on the oe bolt holes is worn beyond being able to put the front into proper alignment.
Super Moderator
It's not really a wear issue. It's a slightly bent car issue. One hard whack into a kerb can knock the front end out slightly requiring the 3 position bolts to correct.
that sucks...got my for 12.75 a piece online. NOw I just need to find a place who can do the camber/caster alignment besides benz.
Super Moderator
You should have installed them so that they are there for the future.
