MB 235.0 Approved Hypoid Gear Oil ( Rear differential )
Old Oct 10, 2010 | 04:18 PM
Xhale707's Avatar
C320 2002
MB 235.0 Hypoid gear oils (SAE 90, 85 W-90, Specification 235.0)
Old Oct 10, 2010 | 06:19 PM
Glyn M Ruck's Avatar
Super Moderator
Please note that you should be using the latest products meeting 235.7 or newer.
Old Oct 11, 2010 | 05:40 PM
NegroC230's Avatar
08 ML CDI
Redline 85W90
Old Oct 11, 2010 | 07:31 PM
Super Moderator
Originally Posted by NegroC230
Redline 85W90
Don't use - not approved - wrong additive system.
Old Oct 11, 2010 | 07:41 PM
NegroC230's Avatar
08 ML CDI
Been using redline products in both manual transmission and rear differential on my 2006 c230 m272 for 2 years now (23k miles). After first month , transmission started shifting slot smoother. This "approved" list is a big BS!
Old Oct 11, 2010 | 08:03 PM
Super Moderator
Mercedes spend a fortune testing & approving lubricants & fluids that are suitable for the vehicles that they design. The oil industry spends a fortune developing products that meet their requirements & some wisea$$ yankee says it's BS.
Having been closely involved with this approval program over an oilco career spanning nearly 40 years I can assure you it's not BS
Old Oct 11, 2010 | 08:04 PM
Xhale707's Avatar
C320 2002
Originally Posted by Glyn M Ruck
Mercedes spend a furtune testing & approving lubricants & fluids that are suitable for the vehicles that they design. The oil industry spends a fortune developing products that meet their requirements & some wisea$$ yankee says it BS.
Old Oct 12, 2010 | 01:01 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
Originally Posted by Xhale707
+1
I can't find anything on Mobil's page, is Mobil 1 Synthetic Gear Lubricant LS 75W-90 approved by MB? I see in 235.7 what looks like a standard Mobilube 75w-85 but no mention of a synthetic.
Old Oct 12, 2010 | 05:04 AM
Super Moderator
Go to 235.8
Old Oct 12, 2010 | 08:02 AM
contact148's Avatar
2003 c240 4matic wagon
good list but i went thru this, this summer in Canada NONE on the MB approved gear oil is available even the dealers use whatever they can get I called 7 different dealers and they use 3 different oils NONE of them on the list
The only way to get approved oil for me was by the 55gal drum or case lot which would have cost me $300.00 + hazmat shipping
Old Oct 21, 2010 | 09:25 AM
BF_JC230's Avatar
2005 w203 C230
No...They can get it...
True most (Dealers / Shops) just pump the "stuff they have" out of a 55 gallon...make, weight, additives, spec sheet...doesn't matter...
I just bought from my Mercedes Dealer 235.11
Thanks all,
Jake
Old Oct 21, 2010 | 11:25 AM
Xhale707's Avatar
C320 2002
Thanks all,
Jake
I changed mine to this
http://www.mobiloil.com/USA-English/..._75W-90LS.aspx
Don't even know if its on this list but yah
Old Oct 13, 2018 | 02:26 PM
DH1951's Avatar
E55 AMG
Having just become a 2005 E55 AMG owner I looked at the "Factory Approved Service Products September 2004" booklet that came with the car. It mentions MB Hypoid Gear Oil (85W-90) as "Meets sheet 235.7 specification".
As this was published in 2004, I presume your advice to look at sheet 235.7 recommendations reflects changes for recommended oil in the past 14 years.
Old Oct 13, 2018 | 03:50 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
https://bevo.mercedes-benz.com/bevol...ets-sort1.html
Old Oct 13, 2018 | 07:49 PM
DH1951's Avatar
E55 AMG
So, 75W-85 differential oil it is for my 2005 E55 AMG. Will be changing soon as have no record of being changed by previous owner.
The old 2004 recommendation was Hypoid 85W-90.
Old Oct 15, 2018 | 05:57 PM
My dealer told me just use any decent GL5 oil.
I mean, it's just gears and bearings. Nothing in there that needs anything special.
I've used Castrol Hypoy C 80w-90 twice in my rear differential at 100K and 200K
245K Miles and no issues with the diff.
Man the original old stuff at 100K smelled like whale barf and was thin and
watery on draining.
Old Oct 24, 2018 | 02:49 AM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
No, they don't. In fact, oil companies pay a royalty fee to maintain approval status. They submit against the same modest specs that other manufactures meet. Nothing special about a gear oil that works in every other vehicle on Earth.
So, the story you told is untrue. You don't even understand the approval process.
Old Oct 24, 2018 | 11:28 AM
DH1951's Avatar
E55 AMG
I decided to follow the recommendations of the MB Sheet 235.7 and purchased the FUCHS TITAN SINTOPOID 75W-85.
Old Oct 24, 2018 | 01:01 PM
75w-85 is for fuel economy, not necessarily for parts longevity.
Gear oil shears a bit in service, or at least older formulas do.
Buying an 85 weight is just buying pre-sheared gear oil, nothing special- no rocket science.
https://www.fuchs.com/de/en/special/...fe-sae-75w-85/
"Premium Performance fuel-economy passenger car axle fluid offering increased gearbox efficiency in passenger cars due to low viscosity level. Reduces fuel consumption"
The fluid and spec book worship is OUT OF HAND with Mercedes drivers.
At least Fuchs is a good product that wont allow corrosion:
I have a quart of Mobil 1 75w-90 that will get topped off with 140, because that's what I already have. Gear oil is BORING. Let's talk GL-4 Manual Trans Fluid if you want to see fireworks.
Old Oct 24, 2018 | 02:55 PM
What am I looking at here? Well at least the Hypoy C I've used for years seems to look good in the photo.
But what is the photo?
What's up with the Lucas stuff? Black. I'm guessing it's burnt?
Titan Sintopoid sounds like some creature that roamed the earth some millions of years ago, who's remains can be found at the bottom of the La Brea tar pits.
Old Oct 24, 2018 | 02:58 PM
Corrosion
Old Oct 24, 2018 | 05:42 PM
DH1951's Avatar
E55 AMG
I appreciate the input.
Many thanks,
Dave
Old Oct 28, 2018 | 03:25 AM
https://www.opieoils.co.uk/c-717-mer...ion-fluid.aspx
