01 C240 Headlight Conversion
This thread might be of help but it very long.
https://mbworld.org/forums/c-class-w203/188766-aftermarket-hid-conversion-kits-required-setting-xenon-present-thread.html
I learned a long while back on this forum not to assume anything.
e.g. presume that lamps are in fact fitted to new light housings ???
What I did is use the fitting (turn signal) from my old housing and used it in the new headlight assembly. There are 4 contacts in your wiring harness and 4 contacts in the early light assembly. The later headlight assembly has 5 contacts in the housing. So you have to use the fitting from the original turn
signal. That is your 5th electrical contact.
Check the bulb holder from both turn signal assemblies. You will see the newer one will have metal contacts around the outer part of the housing and the older one doesn't.
Hope you understand my explanation.
It worked for me, I haven't had any problems since I changed my headlights.
I have photos somewhere if you need to take a look. Good Luck.
My 01 had the metal connectors in the light for the turn signal. But Mercedes put out a fix because they had issues with it. so they spliced the connector and made it hard wired into the light. So originally your 02 had them both thought the light then they switched it to the direct wire style to fix the issue. My car has one hardwired and one normal.
What brand are the projectors because like i said the pins in some of the lights were pushed to far back or bent wrong and that might be why there is nothing working
I tested these DEPO lights on a C32 AMG and they work.
Even the ebay seller is baffled.
Try plugging them in and turning them on with the key out of the ignition. The car doesn't check for proper voltage and if they work then the setting is your issue.
I suspect the c32 has xenon lights and even if it doesn't some cars seem more sensitive about voltages accepted than others.
I have reread a few threads and looks like some of the pins maybe in the wrong place thus the DEPO headlights not lighting up at all in my C240.
Also as for coding, I was not able to code my car at all. STAR does not read / cannot connect with my car. No idea as to why.
I've had these lights sitting here for a year and a half now.. still not installed.
