"Hot country"/"Cold country" settings
Before, when it is in "Cold country" mode
the C240 has 100ºC - 105ºC (212F-221F) when outside temp is 30ºC-40ºC (86F-104F)
the C200K has 95ºC-100ºC (203F-212F)
After, when it is in "hot country" mode
the C240 has 88ºC - 89ºC (190F-192F) when outside temp is 30ºC-40ºC (86F-104F)
the C200K has 77ºC-78ºC (170F-172F)
Beside that Air-condition runs much cooler.
I serached about this topic and could not find any information. Anyone here know this and can share more detail about the setting ? Anything damage may happend if the cars had run more than 7 years with the wrong setting ?
After change the settings: both cars run smoother, climate control is cool faster, cooling fan run more ( i think it start at lower tempeture due to the settings).
There is a different between cars: the c240 engine temp is 89oC and the C200k (m271) is 78oC . The guy said , C240 engine temp can be down to under 80 by replace a double size radiator (2-row radiator). Iam trying to get its P/N. Maybe it is C32s, i am checking
For people is in "hot" area : what is your engine temp ?
I take it you're really gentle and smooth with yours?
