Oil on top of the engine - problem? Normal? Pictures
Old Dec 24, 2010 | 11:20 PM
vert's Avatar
Hers - 2003 C320. His - 2004 330i zhp 6 speed.
I picked up a 2003 c320 with 80K miles on it and trying to go through it so it can be a reliable car for my wife. I bought it from a friend who's had it for the last 50K miles and they've done the maintenance by what the car computer told them, which of course is not that much. No issues, no oil burning or anything like that.
While replacing the alternator, I took the air filter cover off to take a look at the top of the engine and noticed a lot of grime/dirt/oil build up. I know for a fact that my friend did not clean the engine for the last 5 years. Being new to Mercedes, I would like to get your opinion if this is a potential problem (leaking valve cover or leaking smth else) or if this is considered "normal" for this car considering the car's history I described. If it's a potential problem, what would you suggest I should check? I plan on degreasing the engine at some point to start fresh and see if I can notice a leak somewhere.
Attached Thumbnails Oil on top of the engine - problem? Normal? Pictures-dsc05238.jpg   Oil on top of the engine - problem? Normal? Pictures-dsc05239.jpg
Old Dec 24, 2010 | 11:26 PM
laneshift's Avatar
C240
Seems like you have a valve-cover leak. There isn't really a ready-made gasket to use, so most people just buy Black RTV gasket maker and reseal the valve-covers themselves. Easy job, the leak is not rare at all.
Old Dec 24, 2010 | 11:36 PM
sinaa's Avatar
C240
thats the valve cover gasket leak pretty common on c240 and c320 m112 engins.
https://mbworld.org/forums/c-class-w...ing-cover.html
Old Dec 25, 2010 | 10:21 AM
TNblkc230wz's Avatar
C320 Coupe
I cleaned mine off and re-torqued the valve covers which solved the problem
Old Dec 25, 2010 | 05:19 PM
Glyn M Ruck's Avatar
Super Moderator
Torque the valve covers, reseal the captive oil breather covers. Common & not really an issue.
Old Dec 25, 2010 | 05:41 PM
Xhale707's Avatar
C320 2002
Common issue.. but will be an issue if you don't do something about it
Be very very careful with the covers on top~ the screws tend to break very very very easily. I've done the job of re sealing the top part and snapped a screw. Once again when TQin go sloww
Old Dec 26, 2010 | 12:44 PM
laneshift's Avatar
C240
Oh yes, I forgot that part. I had to extract the screw, you have no idea how SOL I felt when I snapped the screw off.
Old Dec 26, 2010 | 01:26 PM
Super Moderator
Use a known accurate torque wrench!
Old Dec 26, 2010 | 07:38 PM
vert's Avatar
What are the torque specs on the bolts? I will try cleaning and re-torquing first.
Old Dec 26, 2010 | 08:36 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Specification is 8 Nm/5.9 ft-lbs/71 in-lbs. for the coil packs, PCV and cam covers’ fasteners. They're steel threading into aluminum so go easy.
Since you’ll be in the vicinity, consider replacing the spark plugs concurrently. Related thread…https://mbworld.org/forums/w211-amg/...ml#post3339541
Old Dec 26, 2010 | 11:17 PM
vert's Avatar
Those torque specs are very low, definitely will need to go very easy on those bolts!
Just to see if i got it right - there are small resurculating covers that are torqued to 71 in-lbs. These are the ones that are probably leaking in my case and for which I would use an RTV sealant if torquing them down does not solve the issue.
Then, there is a valve cover... What's the torque for that?
Old Dec 27, 2010 | 07:38 AM
Super Moderator
They are all 8 Nm - make sure that your wrench is accurate in that range !!!!!!
Old Dec 27, 2010 | 10:00 AM
vert's Avatar
Will do... Thank you all for contributing!
