DESPERATE HELP!!!HELP!!!
Old Jan 4, 2011 | 05:01 PM
danev6972's Avatar
2003 C240
I took out the MAF sensor to clean it. I don't know that I did wrong but it idles very roughly to the point of shutting down and I hear a thumping/clunking sound in the engine. I even took it out & put it back 3 times to make sure it is set right.
I was going to clean the throttle body but I could not find my T40.
Do you think something got into the TB?..or do I need to replace the rubber seal/gasket?...maybe I broke the MAF.
I was fine before I messed around with it..bummer!
Help please!!!!!!!!
Old Jan 4, 2011 | 05:24 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Can you take a photo showing the MAF/TB area? If your car has M112 engine, couple of hoses that connect to the TB area may have been disconnected - causing the rough idle.
Old Jan 4, 2011 | 05:31 PM
pcy's Avatar
pcy
In the picture below, look at the part labeled #158 and the associated hoses. That 158 may have come out of top of TB. Re-check those hoses.
Upon first glance, by looking at the intake tubing, you may think I posted the picture for wrong engine. Trust me, if you have M112 engine, the ventilation hoses and part #158 are on M112 engine. This picture is acutually for M112 on a W163 (ML). Just ignore the intake tubing in the picture. Just concentrate on part #158 and associated hoses.
Old Jan 4, 2011 | 05:58 PM
Glyn M Ruck's Avatar
Super Moderator
C240 diagrams.
Do as pcy says.
MAKE SURE YOU DID NOT DROP SOMETHING DOWN THE INLET MANIFOLD - YOU COULD BEND A VALVE.
Old Jan 4, 2011 | 06:37 PM
danev6972's Avatar
2003 C240
FOUND IT!!!!!!!!!!!!-- see attachment--
Hose must have came out or something. What's that part called anyway?
I guess now I know what it does...
Next is TB cleaning...Hope nothing goes wrong.
YOU GUYS ROCK!!! Thank you for your help.
Old Jan 4, 2011 | 06:44 PM
pcy's Avatar
pcy
that metal pipe is a vaccum hose, it fits on top of #158. Several hoses connect to that single plastic connector. That connector just attaches to the TB, no screws, just push it down.
Attached Thumbnails DESPERATE HELP!!!HELP!!!-m112_ventilation_hoses.jpg   DESPERATE HELP!!!HELP!!!-dsc01165_resized.jpg
Old Jan 5, 2011 | 04:42 PM
danev6972's Avatar
2003 C240
Thanks Glyn & Pcy.
Do you guys know the name & part no. for #113 & #116? It's the rubber seal.
I think I will replace mine...Hope you can buy them separately.
Thanks again.
Old Jan 5, 2011 | 04:55 PM
pcy's Avatar
pcy
112-159-00-80 GASKET
112-159-01-80 GASKET
Although both of those seals look the same, they both have slightly different diameters.
I bought these about a month ago. MB dealer charged me $7 each.
These seals are $4 each from RMeuropean dot com.
Old Jan 5, 2011 | 05:07 PM
pcy's Avatar
pcy
one gasket fits between MAF and the plastic elbow. The other gasket fits between the plastic elbow and Throttlebody.
Old Feb 5, 2011 | 12:22 PM
danev6972's Avatar
2003 C240
Ok I tried to replace the gaskets today. It did not seem to fit in the housing correctly...so i compared the part #s the old ones (#113) A112-141-18-80 and (#116) A112-141-17-80. Now are the part #'s been changed to the ones above?
Bought it from rmeuropean.com [Application: C240 Sedan M112.912- 203.061]
Pls. help...can't use my car until I have the right part...also broke the air hose connector so I have to buy that too.
Old Feb 5, 2011 | 01:41 PM
pcy's Avatar
pcy
yes, the part numbers I posted are the updated part numbers. The part numbers you posted were older part numbers. Please see the attachment (copy/paste from EPC)
Old Feb 5, 2011 | 01:45 PM
pcy's Avatar
pcy
I have replaced those gaskets on my C320 (M112). Line-up the notches in the gaskets with the the elongated holes in the plastic elbow housing and massage it in.
Old Feb 5, 2011 | 02:15 PM
danev6972's Avatar
2003 C240
Thanks PCY...I will work on it once I get the rest of the part/s I need.
Old Jul 18, 2014 | 11:13 AM
RADHAMES's Avatar
1986 300SE; 1996 SL500; 2002 S500
w220 gasket
hi,
i have a w220 s500, and is a little rough at idiling, and sometimes turn on the chek engine light, i says to check the MAF sensor.
whe to my mechanic, and he said that the gasket is a little bit loose, for the time, that i have to get a new one, my gasket number is A 112 141 02 80.
but when i look i found on ebay A 112 159 00 80, are they the same?
what numbers should i look up for?
thanks
picture attached.
Attached Thumbnails DESPERATE HELP!!!HELP!!!-072.jpg   DESPERATE HELP!!!HELP!!!-075.jpg
Old Jul 21, 2014 | 01:13 PM
pcy's Avatar
pcy
For a part like that gasket, it's best to look up in EPC or check with parts dept at your local MB dealer. There may be a revised version/part number.
Old Jul 21, 2014 | 01:37 PM
mguerrero's Avatar
w215 - CL55 w/stage III
where did you get your EPC?
Old Jul 21, 2014 | 05:44 PM
samaritrey's Avatar
Super Moderator
THE C350
http://epc.startekinfo.com/epc/login.jsp
its free with a US credit card
Old Jul 22, 2014 | 12:17 AM
mguerrero's Avatar
thanks so much! just signed up!
