View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Old Jun 15, 2009 | 08:29 PM
  #2901
phoenix_iii's Avatar
2007 ML350
I think the 2002 C230 Kompressor only came in a coupe, and with 16''s. Was there a wheel option for 17''s? [I am guessing yes].
Old Jun 15, 2009 | 09:20 PM
  #2902
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
As far as the tires go, I'm actually pretty impressed with the Pirellis that came on my C63 wheels (meaning they come stock on the C63). Also happens to be the same tire the new Camaro comes stock with. Hopefully they won't go to crap once they get some miles on them, I haven't been impressed with Pirellis in the past. I will be replacing them with the S.Drive. I've become a big fan of the Yokohama brand, I love the Parada Spec-X I have on my Trailblazer.
Old Jun 15, 2009 | 11:44 PM
  #2903
kc2007's Avatar
Bla bla
HERE ARE MY QUESIONS!!! PLS HELP!
***IF YOU HAVE 18s RIM AND TIRES ON YOUR C230, I NEED TO KNOW THE RIM SIZE, OFFSET, AND EXACT TIRE SIZE, ALSO DO THEY CAUSE RUB OR ANY OTHER PROBLEM. I AM GOING NUTS B/C I CAN'T GET AN ANSWER****
I have a 2007 C230 Sport and I've decided on a set of AMG replicas that are 18x8.5 front with 35MM offset, and 18x9.5 rear with 38MM offset.
The tires recommended to me was this:
1) 225 - 40 - 18 front
2) 255 - 35 - 18 rear
Here's my question, one guy from a tire store told me the rear rim with 38MM offset will not be a good look, another guy told me 255 - 35 -18 may be a tight fit and cause "rubbing".
Can someone tell if these tires will fit and look right? Obviously I don't want the tires to look pushed beyond the fender or inward..
HELP!!
Old Jun 15, 2009 | 11:51 PM
  #2904
nychokeyplaya35's Avatar
08' C350, Toyota Tundra
Seems too much for 18" replicas..you could get a better deal shop around.
Old Jun 16, 2009 | 03:27 AM
  #2905
paypaboi's Avatar
03 W203, 13 E350, 13 W204, 14 C218
Cool thanks. Just savn up for the rears now $200/per tire at a local shop
Old Jun 16, 2009 | 08:20 AM
  #2906
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
that's because these PZeros are $300 a piece and competes with the PS2 and Eagle F1 asym. If they don't impress, nothing will. lol
Old Jun 16, 2009 | 11:20 AM
  #2907
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
HELP!!
that sounds fine and you wont get rubbing...I have 19x8 32mm and 19x9.5 35mm w/ 225 and 255 and mine dont rub at all even on bumps...you'll be fine with that set up, infact I'd even play with 235 up front for you since your wider than I am...
Old Jun 16, 2009 | 02:52 PM
  #2908
Nokiemon's Avatar
CLK55 AMG, SL55 AMG, C55 AMG
I have the exact same size rims and tires, and offsets as you are looking at on my 2005 230SS and they fit great, with no rubbing fenderwells or hitting shock towers, and clears the big brakes in front.
They work just fine and upgrading the the 18's upgraded my handilng and ride IMO. The 38ET in the rear fit perfectly and my rears have a 2.5 inch lip that looks great as well.
Old Jun 24, 2009 | 08:06 PM
  #2909
maverik259's Avatar
right rear toyo t1r is drastically fading!!!
anyone got any reasons to this...theres only a few thousand miles on them but my right rear is drastically fading in comparison...especially on the inside of the tire!
Old Jun 24, 2009 | 08:11 PM
  #2910
BigBodyBenzC240's Avatar
...a panty dropper...
Are you rubbing at all? Maybe your alignment is off.
Old Jun 24, 2009 | 08:52 PM
  #2911
iJimpanzee's Avatar
2009 SLK 55 AMG
There are plenty of reasons.
I'll try to list them in terms of easiest to more annoying ways of finding out:
Are you inflated properly?
32 fronts - 34 rears was what I was recommended as the General PSI for treadwear.
Rubbing?
Drive around. Go on some bumpy roads; carefully, and music off.
Alignment?
Find a flat parking lot, set the steering wheel straight, gas.
Are you going off to a side?
35$ at most shops to do a check.
Camber wear?
I'm not quite sure what this is, but from what I've read:
Does this have to do with taking off your entire wheel and checking for 'play'
Faulty Tire?
Contact manufacturer (annoying)
This has what I've done research into when my tire had irregular tread wear.
Old Jun 25, 2009 | 11:30 AM
  #2912
maverik259's Avatar
thanks for the info...ya i know my alignments been off for a few months now...just havent had time to get it fixed and never thought it was terribly a big deal...maybe i was wrong but im taking into a shop tomorrow to get at least the alignment done and maybe the bushings looked at (as was recommended by a MB mechanic bud of my bro's)...thanks for the info and ya my tires are inflate and they dont rub (interestingly enough cuz i thought i would at some point but i never do, go MB shocks!!!)
Old Jun 25, 2009 | 12:56 PM
  #2913
TruTaing's Avatar
Moderator Alumni
w203 m112
Incorrect toe will eat your tires WAYY faster than incorrect camber. I bet your toe is super goofy on the wheel that is eating up your tire.
Good luck. When considering alignment jobs, consider the 140 dollar lifetime alignment offered by firestone. 140 dollars up front and you can take it back as much as you want.
Old Jun 25, 2009 | 01:29 PM
  #2914
benzito911's Avatar
2005 W203 SS
really... thanks for the info.
Old Jun 25, 2009 | 02:02 PM
  #2915
2007 ML350
I heard they dropped this service.
Old Jun 25, 2009 | 04:08 PM
  #2916
maverik259's Avatar
how would my toe angle get messed up???? or myh camber?
Old Jun 25, 2009 | 05:01 PM
  #2917
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
toe-in usually doesn't.
it's your camber.
how much weight are you carrying in the trunk system? keep in mind the gas tank has weight offset to the right even tho still pretty proportioned.
Old Jun 25, 2009 | 05:35 PM
  #2918
W203E35's Avatar
2006 C350 Sport 6MT
it's your camber.
I have a question. Maybe this question might help out on wear as well.
ONly my right rear rubs on hard dips. Who ever I spoke to that have 19" they had the same issue.
Benz, BMW
Will this have to do with the gas tank as well? It makes the right rear sit more?
Old Jun 25, 2009 | 05:39 PM
  #2919
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Benz, BMW
mine is the opposite.
if you look closely some W203's entire chassi is offset to either the right or left for some bogus reason. mine is offset to the driverside and I always have more rubbing issue on the right. mig888's car on the other hand is complete opposite.
it's just how they are. what you can do is trim the inside of the bumper/impact strip tabs.
Old Jun 25, 2009 | 05:49 PM
  #2920
W203E35's Avatar
2006 C350 Sport 6MT
Thanks for the info bro
Old Jun 25, 2009 | 05:57 PM
  #2921
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
did you just changed your username to KARO???
Old Jun 25, 2009 | 06:21 PM
  #2922
W203E35's Avatar
2006 C350 Sport 6MT
Ya, I told Mr. Vanos to change it. It's my real name lol
jk062602kj had to do with a relationship and you know how that is.
Sort of like tatooing a girls name and lasering it off, just less painful
Initaials date and initaials again
Old Jul 31, 2009 | 12:23 PM
  #2923
lmandi89's Avatar
2007 Mercedes-Benz C230 8K HID's Low Beam & Fog Lights
Question New tires for 07 C230 or buy new rims & tires for around the same money???
Hey guys, my tires are pretty much done and i need a new set. I've got 30,000 miles on them. The tires that im looking at are the "Michelin Pilot A/S Plus" and they would cost around $600 but i was thinking instead of buying new set of tires for that kind of money, maybe buying a pair of rims&tires with the same WIDTH front&back so that way i would be able to rotate my tires and, save money in the long run and tires would last a lot longer. I just want to get everyones opinion on this see what you think i should do??? Thank you.
Old Jul 31, 2009 | 12:32 PM
  #2924
Midnight Koop's Avatar
CL203
i have 07 sport wheels and am not happy that i can't rotate. i would go with wheels/tires with the same width so you can rotate. its a big pain in the rear having to change tires so often. it looks good and all to have larger tires in the back, but the impracticality outweighs the look in my opinion
Old Jul 31, 2009 | 02:12 PM
  #2925
kickR's Avatar
'14 CLA 45
Do the math first and see how long it will take you to break even when buying new wheels (same size all around) vs. keeping your current setup and just replacing your rears.
Not doing the math - I would not be surprised if it would take you 4 years to break even and by then you might already have a different car.
For rears I would go with General Exclaim UHP (245/40/17): $105 at tirerack.
I have them on right now and am more than happy with them.
For comparison: I had Good Year Eagle F1's DS something, Michelins and Contis 3 before.
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
