View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
#3026
Super Moderator
My tyre guy fits, balances, 4 wheel aligns & gives me a discount or I don't buy from him
#3027
#3028
1 Post
2008 C350 Benz, GLA250 4matic
What tires should i put on my 08 C350? im looking for all weather...I was looking at pirelli PZero Nero but I want a good tire that is somewhat low pro...anu reccomendations?I want a quality tire...sometime to improve my 0-60. lol jk
#3030
Looking to buy winter tires and rims for the first time for our MB
2003 c230 coupe
is there a specific special dimensions to the rims that I must get?
looking to stay about stock size i think ( 205 55 R16)
would this fit? -
RIM SPECIFICATIONS
Size: 16" x 7", 5 Lug, 120mm Bolt Pattern, 47mm Offset
2003 c230 coupe
would this fit? -
RIM SPECIFICATIONS
#3031
Super Moderator
That offset is for W204. You should be looking at ET 30 to ET 35 range or close.
#3032
#3034
Super Moderator
ET 30 as an example is the positive offset in mm - i.e. The lower the number the further the wheel sticks out. Offset = distance fron clamping face of the wheel to the center line of the rim.
#3035
05.C230K.SS
Reviving thread....
I currently have negative camber in the rear. i just put a little less than 10k miles on the Conti DW, and because of price, I can't afford to change tires every couple months. Now, with that said, I am really leaning towards getting the ghostrider rear camber kit. However, i don't know if correcting camber and dialing back to OEM settings will help much other than knowing i'll have more of an even tread wear across the tire. Or does the camber kit help my rears last longer? Secondly, i feel since im on a staggered setup, tread wears faster anyway, so again, would a camber kit help?
#3036
06 C230 SS 6spd
anytime you lower the car, alignment and tire wear will become an issue if you dont get an alignment done also tire wear is based on the tires as well. since you're running Conti DW the treadwear is 340 i believe theyre gonna wear quick. There are 3 different treadwear systems tire companies can use so one treadwear might read differently from another companies. Instead of getting the DW I say go for the DWS or a tire with a higher treadwear. Get the alignment to OEM spec and you should be good.
#3037
05.C230K.SS
Any other advantages other than even treadwear if i get the rear camber kit?
#3038
MBworld Guru
white and whiter
once the tire starts to wear uneven they will continue to wear uneven if you don't swap them side-to-side. camber arm will help when you get a new set of tires and dial out the negative camber. best to do is to swap the tires side-to-side and force them to wear the other side.
#3039
I drive like my grandmother and I still only get around 15k from my rear DWS'. One of the reasons I went with the DWS' is the 50k mileage warranty.
While I'm at stock ride height I have to doubt that camber is the tire killer. My wear is straight across and I've had cars that ran up to 4 deg negative that never had inside edge wear issues.
#3040
05.C230K.SS
#3042
05.C230K.SS
Thanks for all your help. I think im going to go with frank's approach for now, flip the DW's inside out, do the side to side rotation, and wear em rears out.
Then prob gona do it right...get the DWS, order the camber kit, get it back to factory settings, and get an alignment.
Too bad my falken fk452's came already for my fronts...if i had known this info, i wouldn't have ordered them since they're directional tires...
#3044
ContiPro Contact or Pirelli Pzero Nero?
Bringing back an always useful thread IMHO! So I'm starting to look at tires. My car is stock right now and I plan to keep it this way at least for this first go around of tires so no suspension drop, stock wheels, etc.
I saw that the last post on this thread was from a year ago and that by now there may have been changes in tires offered or just the performance of the tires as perceived from a year ago so here's my question/dilemma:
Go with:
Continentals
ContiPro Contacts 225/45 R17 91H DGE B (60k mi warranty) FRONT
ContiPro Contacts 245/40 R17 91H MBZ BS (60k mi warranty) REAR
or
Pirelli (OEM)
Pzero Nero 225/45 R17 91H XL MBZ (45k mi warranty) FRONT
Pzero Nero 245/40 R17 91H XL MBZ (45k mi warranty) REAR
I plan to rotate them side to side with every oil change (between 6k-8k miles). On of the things I'm wondering about is with the aggressive wear on the rear would making a choice based on 45k mi vs. 60k mi warranty even matter? Even with rotation? If NOT, then I'd go with the cheaper of the two. But if it DOES matter then I'd have to go with the ones that claim to last 15k more miles. Pirelli is the OEM supplier and they have a sale right now so choosing Pirelli could save me OVER $200 for the set so If the rears will last let's say 25k miles which means that 45k vs. 60k does NOT matter then Id' go with them.
I also see that a lot of people on here mention Conti DWS, is this due to the fact that the ProContacts were not available a year ago? Or are they just better than the ProContacts?
The techinician at the tire place I was at this weekend (getting a nail in a tire fixed) mentioned that lately BOTH manufacturers had made some progress in the European car-tire arena to address the aggressive tire wear and have started using a combination of harder rubber compounds on the inside of the tire (to help with the camber wear) while using softer rubber on the outside to help things even out (traction, even wear, etc.).
Thoughts please! and thanks-a-million guys!
Go with:
Continentals
or
Pirelli (OEM)
#3046
Did you go to Tirerack and check out their reviews of both tires? That would have been my first stop.
A tire with a 65k warranty is generally not one I'd probably buy, nor is it one that I'd want to keep that long. Remember that just because it's safe to drive to 65k doesn't mean that you will want to keep it to that ripe old age.
If you're set on either set, and Tirerack's ratings are about the same (check into that), then go with the cheaper. I wouldn't use a longer warranty as much of a carrot to get me to buy the Pirellis if I were you.
Given the first part of your first post, if you're going to change anyway as you make mods, even more reason to not really care about the tires and go with something even cheaper if you can get it. Otherwise, you're throwing money away. Though if you're looking at a 65k tire and saying that you're not going to mod the car until after, are you really going to keep the car stock for 6-9 years? That would be torture.
#3047
Super Moderator
The Conti's are known to be noisy with this chassis. If this bothers you. (not DWS)
Any tire that will do 65K is going to have rock hard compounding & compromised roadholding.
#3048
2016 Chevrolet SS, 2006 Cadillac STS-V
IMO Pirellis and Continentals are both junk. Michelin Pilot Super Sports are good tires and I just put Nitto Invos on my Cobalt and, so far, they seem every bit as good as the Super Sports.
#3049
I am aware that 65k miles on any tires on these cars is as much of a fantasy as a unicorn but this is why I was basically asking for a "conversion factor" of sorts by asking if 65k miles meant more like 25k miles. I'm trying to get a realistic idea of actual versus brochure lifetime for these tires.
Of course I plan on getting wheels but my priority now is to bring the car up to speed. Judging from the condition of the interior and some of the outside, the previous owner had little to no pride of ownership so I'm sure that the car is behind on required maintenance. Because of this I want to focus on making sure things are well with the car before I start throwing wheels, front lips, spoilers, etc.. This is why I don't mind taking my time with the stock wheels on plus right now my wife and I are splitting the car use 50/50 because she totaled her commuter back in june(which is why I bought this car) and she LOVES to curb-rash wheels (she's even done it on her trail bike). So until she gets herself a new commuter then I really don't want her messing up my nice wheels.
As far as 6-9 years... Well, just to give you an idea I bought the car on June 20th and it had 108k miles, tonight it has 118,522 so it would take a little over 6 months to run through these tires at this pace until she gets herself a new car( we commute 120 a day just for work, and then even more on off days as we like to take trips). Tires that came on the car when I got it in June are almost bald already...lol
Thanks for the responses guys!
Glynn, I see your point about the road noise issue. It is something to think about.
#3050
tires on benz alphards?
hey guys i just bought some mercedes alphards without tires for my 2002 c320 and i was planning on going wide with they possibly 15mm spacers in the front and 30mm in the back and i was wondering what tires would fit perfectly with them like maybe no fender rolls or fender work done at all if possibly and im at stock height right now but will be buying coils real soon. if anyone can help me out i would really appreciate it.
