W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
my sedan has a 205/55r16 on 16x7 rim as spare wheel, and i plan on replacing it. im concerned that the wheel n tire might be too wide for the trunk carpet to be placed flat on top of the spare wheel.
Max performance tires have tremendous grip, but also wear out quite quickly.
If you search the forum, you'll find that others have gone to different tires (away from Michelin and Continental), and some of these have given better tread life.
It's a trade-off between performance and life span.
MB even puts a warning in their literature concerning high-performance tires and fast tread wear.
I feel your pain, but this is the way it is.
Not sure what do you mean you need new tires already. Can you describe more? also, if you check your front tires, you'll probably see it only wear on the outside tread. If that's the case you can just remount the front tires to suit the directional tires need.
You might want to try Michellin Sports, I've heard they give you a pretty good life, I have these on my car, but they only have 4k miles or so.
I've always found TireRack's site very helpful because you get feedback from a lot of different people in the survey area.
If they are rated Z and above, you'll get about the same life out of most tires.
With my experience oh pilot sports on both my cars they are both very very low life on the rears. My C230 needed them very qucik and my CLK430 at around 12k are just about bald.
hehe... nah, lets see... for me, my rears have seen about 20,000 miles and they still have about 40% tread left... my fronts had probably around 50+%, but I replaced them cause my SA hooked me up with free replacements...
ya'll must have a lead right foot... my rears is still looking good
btw, i have posted it before but i will post it again that i needed new pilot sport tires at 5k on my C230, and i could swear it was something wrong with the tires and not my driving!
Are u talking about the pilot sport tires? it must be hard for u to tell how many miles u get on your tires since you've have multiple sets of wheels already!
I've tacked on about 20,000 miles on them and they still look great.
I have had multiple sets of wheels on my car, but only for a very limited time.
- I had 19 ADRs on my car for probably under 2,000 miles before it was stolen.
- I then had 18 Brabus Mono VIs on my car for 1 day, but once you go 19s, you can't go back, so I took them off
- I just got new 19 AMG CL wheels on, probably less than 300 miles so far, and my car now has about 23,000 miles.
Therefore, yes, my OEM Michelin Pilot Sports lasted 20,000 miles, and there were still in very good usable condition when I took them off. I wouldn't be surprised if I took it past 30,000 miles on those babies...
LOL, I guess it is somehow possible, but its rare and probally will never happen to me.
You sir will be god if u get 30k miles on those!
A tire is considered legally bald at 3mm depth, so, you figure about another 10,000 miles...
so, should I add in "tire god" in my title too???
btw, lets talk about brake pads... have you had to change them yet? I still haven't changed mine yet...
i believe brake pads (new) have 9 or 12 mm... during my 20,000 miles check up, I had 5mm left (2 or 3mm is when it needs to be changed)... so those will probably need to be changed within 3-5000 miles
my SA is suppose to hook me up with that too... about $250 to change brakes & rotors... if he doesn't, then I'll get the C32 brake kit... that will look badass with the 19 CL wheels...
well... put it this way... i believe the tires originally come with 10/32mm worth of tread as a new tire... during my 20,000 mile check up, the measurements stated that I had about 5mm left, so about 50% left.
About brakes, i am still on my original brakes on both my cars. When the time comes, If i do not upgrade my brakes to the C32's which i was considering on my C230, i will just go with porterfeild low dust pads and get brembo cross drilled rotors on all 4 corners. Thats if i can even wait that long, (i dont think i will).
I will probally see about the low dust pads on the CLK also and maybe even check if brembo had cross drilled rotors for the CLK since i never even looked.
For you on the other hand, the C32 brakes will look sick with the 19" CL wheels. please do it!
LOL, yes please add the tire god thing into your sig 2.
yeah, i think the C32 brakes WILL look sick too... i might even go as far as painting the calipers just to give it a different look...
i think evosport carries the cross-drille rotors for the CLK...
And the painted C32 brakes will look awsome 2, no matter what u do to those brakes they will look good.
Just make sure u post some pics if u get them, i know it will look sweet.
http://www.tirerack.com/tires/tires....m=245YR7F1GSD3
Can I mount 235/45/17 on the stock C7 wheels? or should I just stick to 225?
Thanks in adavanced
