View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Rating: Thread Rating: 10 votes, 5.00 average.
Old Jul 21, 2004 | 04:49 PM
  #1251
[180]'s Avatar
2004 E55 AMG
tirerack
Maybe look at pep boys or something? I think they have like $15 tyres. :p
Old Jul 21, 2004 | 08:10 PM
  #1252
Nimbus's Avatar
Alot of cars
POS tires usually lasts the longest while expensive tires usually wear out fast due to being sticky which gives excellent road holding grip.
Old Jul 24, 2004 | 04:46 PM
  #1253
Smoky's Avatar
MB coupe.
Best tires for high mileage???
My C230K is going through tires too fast.
My original Michelins lasted 10,000 miles, and my current Khumo's wont get 13,000 miles.
So do you have first-hand experience with tires that can give much better mileage? Don't care about performance, I want mileage. Don't care about the Z rating either.
So whatta ya know????
Old Jul 24, 2004 | 06:11 PM
  #1254
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
1) Drive slower
2) Keep them properly inflated.
3) Rotate them more often
4) Buy all season
5) or buy cheap ones at pep boys or equivalent
Old Jul 24, 2004 | 06:13 PM
  #1255
Buellwinkle's Avatar
I got the Bridgestone RE750's on my coupe and I like them. They're one of the highest rated for threadware for a performance tire. They also come in all-season. Don't know about Canada but in the U.S. tires are rated for wear, it's a number molded on the side of the tire and the number is relative. For example, a tire with a threadwear rating of 400 should last twice as long as one rate 200.
Old Jul 24, 2004 | 07:57 PM
  #1256
mleskovar's Avatar
'17 Jaguar XF
Tread life?
I put 62K miles on the original Conti CH95's before changing them. I think driving style and terrain affect tread life the most (given that they are properly inflated and rotated every 5K miles).
Old Jul 24, 2004 | 10:30 PM
  #1257
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
got RE750 and ran them for about 3k miles on my oem rims before I sold the rims. they are rated at 380 treadwear, but are super noisy over any pavement.
currently I'm running the Yokohama ES100. The rating is 280 and I think it's a lot better then the RE750.
btw, how do you guys drive your cars? My original PilotSport lasted 21k miles before I had to get it replaced. Of course that's till the rear are completely bold.
Old Jul 26, 2004 | 12:56 PM
  #1258
SteveS's Avatar
2003 C230 Kompressor Sedan
I have Conti Extreme Contacts with about 14,000 on them. Based on the tread remaining, I easily have another 5,000.
Old Jul 26, 2004 | 01:23 PM
  #1259
CynCarvin32's Avatar
Mercedes Benz
It is all how the car is driven. Had SP9000's and Pilot Sports on an S55 and they lasted 25k per set.
Had Pilot Sports on a C32 (driven very hard) and the fronts were gone in 9k miles.
P.S. Treadwear ratings are not comparable between tire brands. They are only used to show treadwear between tires for each manufacturer. So tread wear between a Michelin and a Toyo are useless but the ratings do mean something when looking at Pilot Sports and pilot Sport AS's.
Old Jul 26, 2004 | 02:44 PM
  #1260
bensitto's Avatar
S550, R350, GL550, ML63 AMG
I have Nitto extreme 555's.
They definitely outlast any other 19" tire I've seen.
Got about 20k on them and I easily have half of the tread left.
They have a harder compound on them.
Check tread life on www.discounttiredirect.com
Make sure your tires are balanced and aligned when needed. That keeps your tire wear down too.
Old Jul 26, 2004 | 09:23 PM
  #1261
Harris's Avatar
I have put on 25,000 miles on my Toyo T1-S and they still have 30% treads left. It is the most durable high performance tire I've ever driven. Sorry, I can only give you testimonials on high performance tires as I have not driven any ordinary tires.
Old Jul 27, 2004 | 10:39 AM
  #1262
Mercedes Benz
25,000 on T1-S's? WOW! SMGC32 and I only get about 2,000 per set! Sometimes it is only 1 or 2 days! Wait might driving style have something to do with it?
Honestly any tire with a ZR or higher speed rating will wear out very quickly. If you want something a little harder I would look for a VR or HR rated tire. These tires will have much less grip but if your driving style is not very agressive you should be just fine. Good luck. ZR tires will get you a max of say 25k per set with minimal hard cornering and acceleration.
Old Jul 28, 2004 | 03:10 AM
  #1263
levelr123g's Avatar
you are very wrong about the tire ratings. all tires from all manufacturers undrgo the same testing. all there numbers are comparable.
http://www.tirerack.com/tires/tiretech/general/utqg.jsp
Old Jul 28, 2004 | 11:36 AM
  #1264
Bobdole's Avatar
C32
Kuhmos 711's
Old Aug 3, 2004 | 06:11 PM
  #1265
erock's Avatar
2003 350Z
**TIRE GURUS*** Please help me chose tires
For my GF's car. She needs new tires for her C230K. These are the choices I found that would fit her car (225/45/17) and affordable. Performance isn't that much of an issue, i just want to know what brand tire would be good for day-to-day driving, safe, and reliable.
-BFGoodrich
g-Force Sport
Blackwall
$105
-Kumho
ECSTA Supra 712
Blackwall
$89
-Kumho
Ecsta KU19
Blackwall
$101
-Sumitomo
HTR Z
Blackwall
$88
-Sumitomo
HTR Z II
Blackwall
$96
-Kumho
Ecsta ASX
Blackwall
$90
-Sumitomo
HTR+
Blackwall
$76
-Continental
ContiTouringContact CH95
Blackwall
$103
-Continental
Blackwall
$103
-Kumho
ECSTA KH11
Blackwall
$88
-Kumho
ECSTA 711
Blackwall
$73
Old Aug 3, 2004 | 07:31 PM
  #1266
davis449's Avatar
2016 BMW Z4 sDrive35i M Sport
I have Yokohama's on my car and I would take them over Kumho's ANY day. The only other tire I would go with would be Bridgestone Potenza's.
Old Aug 3, 2004 | 08:15 PM
  #1267
MJ50's Avatar
Super Moderator
bone stock E55 AMG
from that list, i'll take continental...
Old Aug 3, 2004 | 08:44 PM
  #1268
Harris's Avatar
From your list, I would take Continental as well. But I think you should consider Yokohama ES100.
Old Aug 3, 2004 | 11:21 PM
  #1269
Dr Chill's Avatar
Porcelain Bus
Yokohama ES100 first choice. If you are looking best performance tire for the buck, Fuzion ZRi. Best overall taking cost and treadwear into account, go with the Kumho KH11 but it's a touring tire, not a performance tire.
Old Aug 4, 2004 | 01:39 AM
  #1270
elchinocache's Avatar
c240
i say continental or the bfgoodrich. I have the continental contiextreme contacts on my car and they are way better than my stock michelins. The dry dry and wet grip is really good and the noise is minimal for now (i've only had them on for 3 thousand miles. if you want a good tire thats not to pricey, i've had dunlops and coopers that were not that expensive and had pretty decent performance. I have never heard anything about those kuhmo tires, i dont know anything about them. If you want a good place to look at tire specs go to tirerack.com They got tons of tire evaluations and it will be very helpful in choosing the tire that will fit your needs.
Bennie
Old Aug 24, 2004 | 11:07 AM
  #1271
coop's Avatar
2005 C230
biggest front tires
Will 245/35/19 fit in the front on a 02' c230 coupe?
Old Sep 7, 2004 | 02:15 AM
  #1272
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
2002 C 230 K cupped LR tire
On my recent trans-Canada trip in the C 230 K, towards the end a howling noise was developing on the left which I thought might have been a wheel bearing. I checked the play regularly and it was fine.
I discovered the origin of the noise tonight. Actually, it's a severely cupped LR tire. The majority of the tire is worn normally but the inside edge is massively cupped, in one point now it's down to the belts! Holy smokes dude!
Hmmm.
The car's never been in an accident where the rear was involved. It did have a minor hit on the LF wheel at one point earlier this year (other driver's fault) but wheel alignment was supposedly verified at the time of that repair.
It has 60,000 km and the MXV4 tires (16 inch HR) have about 4 mm of tread on them, except for the cupped tire's inside edge.
Usually cupping is caused by some play in the suspension, allowing the tire to oscillate somewhat. Considering it's the inside edge, it also might be toed out quite a bit. Camber looks normal to my eye.
Before the dealer investigates this wednesday, any thoughts?
TIA
Old Sep 7, 2004 | 05:37 AM
  #1273
Rick's Avatar
C230K Coupe/Orion/C4/C5/CD/AMG Spoiler/V60/TeleAid, 2 MGB's
Originally Posted by Mike T.
any thoughts?
Were these tires rotated at regular intervals?
It may also be thet the one tire is bad and the belts separated, causing the tread to cut away from the inside, appearing as excessive wear.
I experienced this problem with a set of factory installed Michelin's on a Toyota Supra I used to own (at around 7k miles!)...Toyota refused the warranty and I had to go through the manufacturer to get it 'replaced'...
Old Sep 8, 2004 | 01:34 AM
  #1274
Mike T.'s Avatar
I'm leaning towards the grenaded steel belt theory at the moment (because a wonky suspension is incomprehensible to me). The car will go to the dealer on the 8th and we'll see. The tires had been rorated by the dealer, though the last 20,000 km or so this tire was on the LR (as I wrote, I jsut got back from a LONG trip in this car).
Thanks for the reply.
Old Sep 8, 2004 | 10:50 PM
  #1275
Mike T.'s Avatar
Follow-up:
The diagnosis was a largely out-of-adjustment LR suspension. The car was taken to an alignment shop where two new camber bolts / pins part no. 000-330-00-18 were needed.
So the Michelin tire was not the culprit, but rather the victim of a wonky M-B suspension
The car - as I wrote - had bever been hit there or curbed so this must have been a factory defect. Perhaps a bolt worked loose - I'm speculating here because I wasn't able to talk to either the shop that did the work or the service advisor at M-B.
Interestingly, the car did not drive unusually poorly though the tires did squeal quite a bit when turning right (not left) at moderate speeds. That should have been a clue.
With the 2 pins, the adjustment and a new Michelin MXV4, we're back on the road again, in a safer condition....and somewhat poorer
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
