View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Old Nov 21, 2007 | 11:51 PM
  #2351
amaz's Avatar
2012 X166 GL
Question 19" Tire question
I just bought SSW S19 wheel 8.5 front, 9.5 rear. I have a 2001 C240 with stock suspension.
1. Does 235/35 and 265/30 TOYO T1R tires fits my car with no rubbing issues?
2. What is the ride quality like compaes to my stock 16" contis
3. Any other tires size you would recommend for better ride quality?
Thanks for input.
Old Nov 22, 2007 | 12:03 AM
  #2352
LuxuryC240's Avatar
2003 C240
Thanks for input.
The comfort of my ride with that size is very good...I have 2003 c240 the fit is pretty tight in my opinion...I didn't rub at first, but now I rub when I turn the wheel all the way....but that is only because I changed my headlights myself and when putting the bumper back on, it must have not gone on exactly as it was previously...
Old Nov 22, 2007 | 12:11 AM
  #2353
e1000's Avatar
a quarter mile at a time
Thanks for input.
1. those are the correct sizes. about 2% larger rolling diameter than stock though (FYI)
2. Ride should be somewhat harsher, but more responsive due to MUCH less sidewall.
3. no
Old Nov 22, 2007 | 12:25 AM
  #2354
AJTanner's Avatar
2003 C230 Coupe
i myself, well with the coupe would go for 18's , simply because you wont have to buy such low profile tires, less gas consumption than 19" rims, you wont have to baby your car driving it as much as you will have to 19s.. 1 friend of mine drove over a tiny pothole with 19" rims going like 60kms and his rim bent, probably because they were crappy rims, but still..
Old Nov 22, 2007 | 12:55 AM
  #2355
LuxuryC240's Avatar
2003 C240
lol...unless you have an upgraded suspension, the potholes are pretty rough, but the ride for me was sorta close to stock on very smooth surfaces...luckily my rims were very strong...I hit tons of potholes this summer and my rims are still in almost perfect condition, which makes me very happy...and yes, i babied the car and drove like grandma with 19s
Old Nov 22, 2007 | 11:55 AM
  #2356
moc320's Avatar
2002 Mercedes C320 Sport Sedan, Lexus Rx300, Dodge 2500 Cummins
Thanks for input.
I dont know how much suspension difference there is between the 01 240 and a 02 c320 but i had to run a 15 series tire on my old 19's in order to not rub.
Old Nov 22, 2007 | 01:01 PM
  #2357
AJTanner's Avatar
2003 C230 Coupe
im going to get the brabus mono vi's in spring.. dunno what i should get 18's or 19's ... chrome.. not chrome.. help?
Old Nov 22, 2007 | 10:43 PM
  #2358
e1000's Avatar
15 series?
Old Nov 22, 2007 | 11:00 PM
  #2359
C24owner's Avatar
'08 E550 4Matic
Originally Posted by e1000
15 series?
15?
25 series is as low as you can get.
Old Nov 22, 2007 | 11:26 PM
  #2360
KIRA's Avatar
2002 C230 coupe , NOt THE AVATAR!!
235 will rub a tiny little bit
so i might go for 225 later when i wanna slam my car
Old Nov 22, 2007 | 11:27 PM
  #2361
Shake's Avatar
IS300
19's not chrome. Black center with chrome/polished lip would look good or just the brushed finish
Old Nov 23, 2007 | 10:18 AM
  #2362
jay_mark_paul's Avatar
Mercedes C230 SS Komp
Yes the 235-35-19's and the 265-30-19's should tuck perfectly with no rubbing issues. AS long as the offset is correct!!!!!
Old Nov 23, 2007 | 06:31 PM
  #2363
moc320's Avatar
Originally Posted by C24owner
15?
sorry that was a mistype. its a 25
Old Nov 23, 2007 | 08:41 PM
  #2364
AJTanner's Avatar
2003 C230 Coupe
i dunno if i want the black spokes. i know itll look good, but do you think its going to be like a passing trend then get cheesey?
Old Nov 24, 2007 | 05:58 AM
  #2365
amaz's Avatar
2012 X166 GL
Thanks for your help guys.....
Toyo 265/30R19 is out of stock in my area, can i use 255/30 or 255/35 for my rear(19 x 9.5) instead?
Old Nov 24, 2007 | 11:02 AM
  #2366
e1000's Avatar
you can use front 225/35R19 and rear 255/30R19 instead. it's actually a closer match to the original overall diameter
Old Nov 25, 2007 | 07:06 AM
  #2367
amaz's Avatar
2012 X166 GL
what about 255/35 at rear? (19x9.5)
Old Nov 25, 2007 | 11:33 AM
  #2368
e1000's Avatar
5% too tall in overall diameter. Not suggested.
Old Nov 25, 2007 | 07:47 PM
  #2369
amaz's Avatar
2012 X166 GL
my offset is 38 and 35(19x8.5 Front and 19x9.5 Rear). Is this correct size?
pic of my wheel, ignore the audi center cap
Old Nov 25, 2007 | 08:02 PM
  #2370
B189s's Avatar
1996 MB E320 & 2010 Nissan Elgrand
my offset is 38 and 35 (19x8.5 and 19x9.5). Is this correct size?
35F and 38R?That's what I have and same specs too. You might want to get round form 245s/255s, so that your inner sidewall tires don't rub with your inner fender. I have the boxy General UHP 265s and my rear tires were like REALLY sticking on the inner fender (Couldn't even be spun..), had to use 3 MM spacers,still do untill now.
The ride should be OK with 19s and stock suspension, BUT rubbing and bottoming out likely will happen pretty often. Are going to get new suspension?If not, I'd stick with the 16s.
Nice wheel tho
Old Nov 25, 2007 | 08:19 PM
  #2371
AJTanner's Avatar
2003 C230 Coupe
damn i like those rims.. i wanted to find something like that before.. i got a brabus kit.. i was wondering if i should just go all out brabus lol but those rims are nice...just gotta take off the audi cap haha
Old Nov 25, 2007 | 09:32 PM
  #2372
Phin's Avatar
06' BMW M3
I'm running on 19's(TSW Bremmas) and have 235's in the front with 265's in the rear(Nitto 555's).I'm also lowered with H&R springs and have no rubbing issues.
Old Nov 25, 2007 | 11:32 PM
  #2373
B189s's Avatar
Mono VI Brabus!
Old Nov 26, 2007 | 05:31 PM
  #2374
Andonixxx's Avatar
SL450
what offset do you have? im trying to boy 19's same size the offset is 31 not sure if it would rub?
Old Nov 26, 2007 | 05:34 PM
  #2375
Andonixxx's Avatar
SL450
Smile
do you guys think for a c230 2006 19''s 235/35/19 & 265/30/19 with 31mm offset would work ?
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
