Solved my lack of low end power
Old Feb 10, 2011 | 02:38 AM
W203E35's Avatar
2006 C350 Sport 6MT
Hey Guys,
I think I solved my lack of low end power. The painting of the volks have been put on a hold until I change out my bushing and finish suspension work. I put my stock wheels on and today was the first day I gave it a pedal to the metal from a stop. I feel a significant difference.
I figured out my stock diameter is 24.7 and the aftermarket wheel diamater is
25.3 = .6 inches. I mean half an inch should be a significant difference to feel right?
I believe they are both the same weight...if not very close.
Only way to figure out is Irwindale. Whose coming to Irwindale next Thursday??
Old Feb 10, 2011 | 03:29 AM
phister's Avatar
06 C230 SS 6spd
But your aftermarket are wider right? Youre using more power to get all the wheels to rotate, you have more contact area to move.
Little experiment, place one finger a counter and push it, it's pretty easy to move it forward right? now put all your fingers on the counter and try doing the same thing, it takes more effort to move it. Its the same with your wheels. Didnt feel like thinking of a better experiment to do lol
Old Feb 10, 2011 | 04:53 AM
W203E35's Avatar
2006 C350 Sport 6MT
Thanks that makes perfect sense.
Old Feb 10, 2011 | 05:00 AM
phister's Avatar
06 C230 SS 6spd
its all about rolling resistance. i felt the same when I had my cls wheels to my new wheels. Car feels like it accelerates better. They're just as wide but my circumfence is lower and my tires are not as wide.
Old Feb 10, 2011 | 05:07 AM
W203E35's Avatar
2006 C350 Sport 6MT
Damn, I feel bad for milkman (C230 NA) who has a straightpipe with 19x9.5 running 285/30/19!!! or was is 275 eighter way. No wonder he complains about power. He's got those SL wheels too so I'm sure their pretty heavy too.
Old Feb 10, 2011 | 09:07 AM
phister's Avatar
06 C230 SS 6spd
yeah factory wheels are pretty heavy. I'm glad my new wheels are forged. Depending on the car maker they use different companies to do their wheels. On subaru they use enkei for the factory wheels then go up to bbs for the sti models.
Old Feb 10, 2011 | 02:36 PM
Midnight Koop's Avatar
CL203
Hey Karo,
I don't think that 0.6in more is causing the lack of power you're feeling....
GIVEN:
Inertia Resistance (IR):
where:
IR = inertia resistance [N]
m = car mass + equivalent mass of rotating parts [kg]
a = car acceleration [m/s2]
mcar = car mass [kg]
meq = equivalent mass of rotating parts [kg]
= [ Iw (1/rw)^2 + Ip hf (if /rw)^2 + Ie ht (if ig / rw)^2]
where:
Iw = polar moment of inertia of wheels and axles ≈ 2.7 [kg m2]
Ip = polar moment of inertia of propeller shaft ≈ 0.05 [kg m2]
Ie = polar moment of inertia of engine ≈ 0.2 [kg/m2] + polar moment of inertia of flywheel and clutch ≈ 0.5 [kg m2]
hf = mechanical efficiency of final drive
ht = mechanical efficiency of transmission system (hg x hf)
ig = gearbox reduction ratio [ig1 or ig2 or ………….]
if = final drive reduction ratio
rw = tire radius [m]
* ( + ), (+) with the car in acceleration. {tractive resistance}
(-) with the car in deceleration. {tractive effort}
if the wheels actually do weigh the same...
and if rw increases by 0.6in
aftermarket - stock --> (25.3 - 24.7 = 0.6in)
(or 25.3/24.7*100 = 2.43% increase)
then the equivalent mass of rotating parts actually decreases with (1/rw)^2
meq = [ Iw (1/rw)^2 + Ip hf (if /rw)^2 + Ie ht (if ig / rw)^2]
= (1/rw)^2 [Iw + Ip hf (if)^2) + Ie ht (if ig)^2)]
as rw increases, (1/rw)^2 decreases
after some math, it goes down by 4.69%
therefore, you actually have less rotational inertia or resistance from the wheels by almost 5%
unless i totally goofed something
Old Feb 10, 2011 | 02:40 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
my head hurts.
Old Feb 10, 2011 | 02:46 PM
mskembo's Avatar
2010 Mercedes-Benz E350
I work with that guy... and he's mean.
Old Feb 10, 2011 | 02:55 PM
W203E35's Avatar
2006 C350 Sport 6MT
Thanks for all the input guys.
Originally Posted by midnight kompre
Hey Karo,
GIVEN:
where:
where:
therefore, you actually have less rotational inertia or resistance from the wheels by almost %5
Are you sure you didn't come up with the E=MC2??
So what you're saying is I'm feeling a placebo effect?
Old Feb 10, 2011 | 03:05 PM
CL203
with me?
Old Feb 10, 2011 | 03:07 PM
CL203
possibly... i'm no expert... but i'm just following the math and it seems to say that if anything, you should have an advantage.
do you know the exact weight of both wheels (stock and aftermarket)?
Old Feb 10, 2011 | 03:08 PM
seagel1000's Avatar
05 C230 Kompressor
Quite certainly lol
Old Feb 10, 2011 | 03:33 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
How the hell are you going to post all those formulas and then follow it up with "I'm no expert."
Old Feb 10, 2011 | 03:38 PM
draz.amg's Avatar
'13 F10 535i / '05 W211 E55
i was thinking the same..
Old Feb 11, 2011 | 02:37 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
I'm more of the belief that the rolling diameter change mostly affected your net gear ratios. A smaller tire gives you an effectively lower gear ratio.
I'd work out the change numerically, but my head still hurts from that inertia bit above.
Old Feb 11, 2011 | 02:54 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
..Who's coming to Irwindale next Thursday??
Is that tomorrow or next week? Might have to knock off work early.
edit: almost certain it'll beat up on a mildly-modified G35/37
Old Feb 11, 2011 | 07:38 AM
CL203
only because i didn't derive the forumlas, i only rearranged them to isolate variables and plugged in values to get an estimate. i get bored at work sometimes, so this is my outlet
i think if gear ratio and tire diameter were correlated, then they wouldn't be listed as independent variables in the formula...
Old Feb 11, 2011 | 09:03 AM
lkfoster's Avatar
I'm too lazy to work out the numbers so I found this link instead.
http://www.ausfish.com.au/vforum/arc.../t-148715.html
Old Feb 11, 2011 | 11:50 AM
Milkm4n's Avatar
2006 c230
Karo its all about the look
Old Feb 11, 2011 | 12:19 PM
eesjunin's Avatar
Nowhere ...Fast
How abou the COF? its much higher with wider wheels...by looking at the formulas its not present...
Old Feb 11, 2011 | 01:07 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Wait... dont you have Kleemann headers on your car?
Old Feb 11, 2011 | 03:44 PM
phister's Avatar
06 C230 SS 6spd
he has the knockoffs I think
Old Feb 11, 2011 | 04:52 PM
W203E35's Avatar
2006 C350 Sport 6MT
Hey Splinter, that's next week.
No not Kleemann, OBX . Over 6 months and they are still great. Definitely a Kleemann replica. I would recommend them....actually I have and many w204 guys have asked me about them. I think people keep their OBX headers down low because of the brand
OK, so the aftermarket wheels (not weighed but lifted to compare) feel a little heavier.
Only way to really know is at the race track.
Old Feb 11, 2011 | 05:01 PM
eesjunin's Avatar
Nowhere ...Fast
I bet you COF=coefficient of friction plays a good part too along with heavier wheels
