Old Jun 10, 2015, 12:58 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Powertrain
Print Wikipost
M272 Spark Plug Replacement
Rating: Thread Rating: 2 votes, 5.00 average.
Old Mar 1, 2011 | 10:02 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Attached are the WIS documents for spark plug replacement on the M272 engine. I am at 85K now so I am getting ready to replace them.
File Type: pdf
File Type: pdf
Old Mar 1, 2011 | 10:32 AM
billbillw's Avatar
2001 E55 AMG (sold)
John,
Are you going to buy the special Mercedes spark plug wrench or try it with a standard plug socket and a u-joint? Let us know how it goes either way.
Thanks for posting these. I've got awhile before I need to do mine, but its nice to know the docs are here.
Old Mar 1, 2011 | 10:37 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
In the Spark Plug replacement WIS, step 1 is "Turn key in ignition switch into position 0". I wonder why they want you to keep the key in position 0. I would've thought to remove the key entirely from the ignition since you 'd be working with the spark plug cables and ignition coils.
I was expecting the step 1 to be "make sure the keys are not in the ignition".
Old Mar 1, 2011 | 05:10 PM
johnand's Avatar
Super Moderator
Originally Posted by billbillw
John,
Already had one of the plugs out when I was diagnosing my starting issue. I used a standard 5/8-16mm spark plug socket with no swivel or u-joint. Worked perfectly, so no I will not be buying the MB spark plug socket. I see no good reason to on the M272.
I noticed that too. From what I have deciphered MB meaning of key in position "0", translates to no key in the ignition and/or ignition off. Don't think the coils are energized in the "0" position. I will personally keep my key out of the ignition when replacing the plugs.
I will probably replace the spark plug connectors too just in case.
Old Mar 2, 2011 | 01:22 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
So, out of curiousity are there 6 plugs or 12?
Ha, you have the CP's right on top of the plug like the M111.
Well, you don't need wires, but the CP's get cooked from the heat.
Old Mar 2, 2011 | 01:59 PM
pcy's Avatar
pcy
My '07 C280 (with M272 engine) has 6 spark plugs.
Old Mar 2, 2011 | 11:17 PM
mighty mak's Avatar
05 c230
I just replaced my plugs last month with the keys out, the car seems fine. Do you know why it would have to be in position 0?
Old Mar 3, 2011 | 03:26 AM
phister's Avatar
06 C230 SS 6spd
which spark plugs did you go with John? NGK?
Old Mar 3, 2011 | 08:53 AM
pcy's Avatar
pcy
I think "Turn key in ignition switch into position 0" is equivalent to the following - NOT to have the key in the ignition. Position 0 in the ignition is same as key off except the steering is unlocked.
I see no other reason to have the key in the ignition (even in postion 0) while replacing the spark plugs.
Old Mar 3, 2011 | 10:48 AM
johnand's Avatar
Super Moderator
The OEM Bosch Platinum/Iridium.
Old Mar 3, 2011 | 11:49 AM
e1000's Avatar
a quarter mile at a time
Spark plug replacement on the M272 is very easy and straightforward without the need of any special tools or equipment beyond what every DIY'er should already have.
M272 only requires 1 plug per cylinder.
Old Mar 3, 2011 | 03:32 PM
Midnight Koop's Avatar
CL203
out of curiosity.... did you replace the coils too?
i'm about to buy a set of plugs for my m271 and was wondering if replacing coils is something i should do too..
Old Mar 3, 2011 | 04:56 PM
pcy's Avatar
pcy
Unless there is anything wrong with the existing coils, no need to change them.
Old Mar 4, 2011 | 02:31 PM
carbonfiberwhor's Avatar
2006 C230, 2006 BMW M3, bye bye C55:(
Seems pretty easy. Thanks for the links!
Old Jun 9, 2011 | 12:12 AM
Did this the other day, extrememly simple and can definitely feel the improvement
Old Jun 9, 2011 | 09:27 PM
zerocover's Avatar
2007 C280 4Matic
So what plugs did you go with?
Also how often should we change these? I was under the impression that platinum plugs last for 100,000 miles.
Old Jun 9, 2011 | 10:35 PM
Moreira_C230's Avatar
2006 C230 SS
Unfortunately I can't add any more than has been added above, but after looking at the set up, it does not look like it would be very hard to do at all. I love how much room there is to work with the 272 engine.
Old Jun 10, 2011 | 11:38 AM
Glyn M Ruck's Avatar
Super Moderator
They are good for 100K if you run them in the self cleaning range for most of their life. If you potter around town & do many short trips they will not go that distance.
Old Jun 10, 2011 | 04:09 PM
I used the stock ones. No point in changing that since they ran me very well
Old Apr 9, 2012 | 01:24 PM
SkankZ's Avatar
2006 C230 SS
2006 C230. I'm at 46,500 miles and it's time for Service B. A indy quote me $500 for service B and change of spark plugs.
Is it time for me to change my spark plugs also? I've seen thread where people replace it at higher mileages.
Old Apr 9, 2012 | 01:27 PM
kluvsbenz's Avatar
2014 E350, 2006 C350 Sport(made it to 280k, loved it!), 1990 300E
On my 06 C350, spark plugs were recommended at 78k. It may be different on yours. Look in your manual.
Old Apr 9, 2012 | 03:21 PM
johnand's Avatar
Super Moderator
For some strange reason MB lists 06 C-class with a 5year/78K change interval and 07 C-Class as a 5year/91K change interval. Even though there was no major changes from 06-07 on the M272 engines, and both 06 and 07 use the same spark plug number.
As Glyn pointed out if you run mostly highway you can get 100K out of them. I have 100K on mine in my 07, and they look damn good, so I have yet to replace them. Plan on replacing them shortly though.
Old Apr 9, 2012 | 03:54 PM
kluvsbenz's Avatar
That was my assessment from looking at my spark plugs at 90k. They seem fine to me. I believe I will wait until I pass the century mark before I give them another look.
Old Apr 9, 2012 | 05:34 PM
RedStripe's Avatar
2010 SLK350
I had one bunk downstream oxygen sensor that was causing the opposite bank to run pig rich, at a ST fuel trim of -25%!!
Anyway, even at only 70k miles, it didn't take long of it running that rich for it to foul one entire bank's worth of plugs in a hurry!
Replaced with OEM Bosch, something like $80 for all 6 (ouch!).
And then of course the 15 minutes it took to change was a breeze.
Old Dec 13, 2014 | 11:28 PM
elektron3030's Avatar
2005 C230K Sport Sedan
This is super old, but I was wondering why as well. Then it dawned on me. This is a service program, so the customers' keys stay in the ignition I'm sure.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
