SLUDGE!!! I think I need a hug...(pics)
The first thing I did was an oil change/flush. I noticed the original oil I drained out was pretty dark so onto the flush then change and I did the same thing one week later just in case.
after the second oil flush on the second week, I changed the oil 1 more time just because I am **** like that and I wanted to see the condition the oil was in. All seemed great!
Now I'm at work and I figure since we had the v/c gasket in stock, I'd go ahead and buy it so I can pull the valve cover and look for signs of and sludge, kinda hoping for the best but still expecting the worst...
So here's what I saw...
NOT PRETTY!!!!
Now I've seen worse looking at pictures online, but I have NEVER had a car with sludge! So my obvious question to you guys is....Do you think it's real bad? Is my car running on borrowed time???
I'm wondering if you think that there is sludge like this in my oil pan asa I am worrried about my pick up getting clogged and I'm am worried about sludge getting stuck in the oil passages and stopping my poor engine from getting the precious lubrication it needs and deserves!!!
Here are some after pictures:
Any advise would be GREAT!
Going on the absence of a white colour it does not seem to be caused by water so that is a relief.
If it is possible without too much trouble removing the sump pan & cleaning would be in my opinion, a good idea.
I would then receive expert advice from an oil chemist on what I could run in the engine to clean it internally without dislodging too much sludge too quickly & blocking your oil channels.
I would then change the oil & filter at half the recommended mileage for the next half a dozen changes.
How people can neglect an engine like this is a mystery to me. I hear of this approach to lease vehicles on this forum.
How did the service book look?
I hope that you can sort it out . Please let us know how you go.
Thanks again for the input guys!!!
I wonder if they used conventional oil or if they used synthetic that did not have the right MB 229.5 specification on the bottle.
Stick to the OEM specified Mobil 1 0W40 European Formula and I don't think that you will have a problem. Mercedes has not had any major problems with slugging, other company's such as Audi, VW, Toyota has had several issues
If you want to go belt & bracers you can pull the sump but probably not necessary.
I don't know the stuff John is suggesting but he will always provide wise advice. Whatever you use must be designed for the job & not loosen any remaining crap quicker than the oil can disperse it or you can clog an oil gallery or filter with dire consequences.
229.5 oils are highly detergent & a couple of 5000 mile oil & filter changes after running Johns stuff should ensure a spotless engine.
Your run the Auto-RX for 2500 miles (For sludge change filter at 1000-1500 miles), then run a rinse for 3000 miles, then repeat. This is the safest way to clean a sludged engine that I know of. Search on Bob is the oil guy forum, and see some amazing results from Auto-RX. It is essentially high grade esters in a carrier oil. With the low change intervals during the treatment, I don't see a problem running a conventional oil.
He ran Auto-RX for a little over 3,000 miles with conventional oil, then switched back to Mobil 1 0-40 synthetic. He did his next oil/filter change at half-mileage to make sure there was no repeat issues as a safety precaution and everything was ok. He even sent a sample of oil to Blackstone for analysis to see if there were other issues, and it came back fine after utilizing the RX treatment.
Meant to mention that this situation is not helped by relatively poor US fuel.
You have got the most dangerous stuff out already - Now let's clean up the sump & lower engine including the oil pickup.
Once clean return to 229.5 Benz products & it will stay clean.
