Help-How to tighten the turn signal/cruise steering collar
I have a 2005 C 230 and the collar where the turn signal and the cruise control is loose.
It actually moves rotates when I signal or use the cruise.
There is a hole on the bottom of the plastic cover where there is torx screw, which i checked and its tight. Is there any other screw that holds the collor from rotating.
I did a search and was unable to find anything related.
Any help will be appreaciated.
Thanks in advance,
AL Z
Read through the entire thread cause you'll need to dismantle the whole signal assembly (once there is a solution) to get to this sleeve.
https://mbworld.org/forums/c-class-w...placement.html
Totally seems to work though. Put it on the side away from you, and cram as much of it as you can into the gap between the 2 sliding parts.
Afaik the collar is only loose because of a manufacturing flaw. I'm pretty sure it is a (supposed to be permanent) press fit gone bad. Honestly they should've used a fastener during assembly instead.
Other people have fixed this problem this way, by drilling a hole through the collar into the cylinder part and adding a screw, but I found that way too risky in case I drilled too far. The glue can always be scraped off or the bonding area split using a knife.The screw accessible from underneath secures the plastic shroud around the collar. Tightening that does not help as the problem is not between the shroud and collar, but between the collar and jacket.
My apologies,
I am sure you will find it when you search YT.
Leon
