need to change my water pump now my 2003 c240 4matic wagon has the cooling water preheater so this means that the lower rad hose connects to it then a VERY short piece of hose connects to the water pump I doubt i cand line the pump up and connect this short hose
has anyone done this???
the pic looks like 1 bolt holding the pre heater on to the engine
also my pump came with a rubber gasket and a metal flat one are they both needed???
You only need to use one of those two gaskets. When you remove the old pump, you will know which one to use - likely the metal one. These pumps are used on many models, some use rubber gasket and others use metal gasket. So, the manufacturer packages both. On my (M112) C320, I needed to use metal gasket.Originally Posted by contact148
...also my pump came with a rubber gasket and a metal flat one are they both needed???
Quote:
thanks did you have the engine pre heater thing on yours??
oh and did you remove the rad fan??
I didn't have to remove the radiator fan or anything else when I changed the water pump on my C320 (M112).Originally Posted by contact148
thanks did you have the engine pre heater thing on yours??oh and did you remove the rad fan??
Removing the radiator fan will give you more room to work with.
Quote:
What's this? Never heard of a water preheater......Originally Posted by contact148
...my 2003 c240 4matic wagon has the cooling water preheater ....
Pic?MBWorld Fanatic!
pre-heater is for the windshield washer fluid.
nope its on the canadian models
its a block heater
here is a view from the top
and here is the preheater unit the short hose attaches to the water pump then to the preheater then to the lower rad hose....
ill never get that short hose back on so i figure ill unbolt the preheater from the block and once disconected ill remove the WP with the pre heater attached and deal with it on my beanch and install in reverse
its a block heater
Can't you just disconnect the hoses at the pump and remove it?
I don't see the problem you think you'll have. Am I missing something? First time I've seen a coolant heater. The water pump R&R is easy.
I don't see the problem you think you'll have. Am I missing something? First time I've seen a coolant heater. The water pump R&R is easy.MB World Stories
Explorewell yes i could but being the hose is SO short getting it back on well i line up the new pump and gasket to the block is going to be a PITA as its hard to reach and i wont be able to get around to the back of it
coolant heater came on many canadian cars
the plug (cord) was the optional part.......
It may be easier than the non heater version because you can easily access and loosen just the lower clamp of the short hose. Once you get the belt and pump pulley removed you'll see how accessible everything is.
well if it ever stops raining here ill try it without removing preheater I need to go to mb and get coolant anyways
