2007 C230 Sunroof issue
Old May 18, 2011 | 11:30 AM
hellsbells's Avatar
2007 C230 Sport
Hey All,
Proud new owner of an MB, glad I joined your crew. I am having an issue with my sunroof when I try closing it. I need to keep the button pressed in the entire time for it to close completely. If I let go, it will reopen every third of the way.
I was told there is a way to reset the sunroof by tapping that button in a certain sequence. Does anyone know the sequence for resetting the sunroof?
Thank you in advance,
JBells
Old May 18, 2011 | 12:25 PM
fookoo303's Avatar
2003 c240
open the sunroof and hold the switch open for ten seconds. Then close the sunroof and hold the switch closed for ten seconds.
Old May 18, 2011 | 05:04 PM
hellsbells's Avatar
2007 C230 Sport
no success
Thanks for the advice. I did what you said, UNFORTUNATELY it did not work. Does anyone have any other suggestions? Thanks for the help.
JBells
Old May 18, 2011 | 05:45 PM
stephen727's Avatar
2004 C240 4Matic
Sounds like you may need to clean and lube your sunroof tracks. There are places that sell the lube parted-out, I think about $12 shipped. A quick Google search will find the DIY (maybe in the E-class forums).
If that doesn't work, check the tracks for damage, and prepare for from your dealer. Good luck, and let us know how it turned out.
Old May 18, 2011 | 06:32 PM
jogger's Avatar
02 S500
i have same problem and some lube made it work fine
Old May 19, 2011 | 09:25 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Step 1, clean and lube the tracks. This fixes the problem for the vast majority of cars. If that does not work, step 2 is to reset open/close data via STAR diagnostic. If that doesn't do it, step 3, is to change the force/current setting via STAR diagnostic.
Old May 19, 2011 | 02:58 PM
lzbenz's Avatar
2007 C280 4matic
I have the exact problem on my 2007 C280 and so far have just been closing it by holding the button down. I plan to try any of the suggestions made but I'm not real optimistic that lubing it will make any difference because I've noticed that even if I 'help' it close by lightly pushing on it, it still opens back up a third or so. But I hope to be proven wrong......
I have tried resyncing it according to the instructions in the manual and that hasn't made a difference.
Old May 19, 2011 | 08:26 PM
anonymousmoose's Avatar
Audi A4 Quattro 2013
refer here:
https://mbworld.org/forums/c-class-w...ose-issue.html
I have the same issue. Did a resync and it worked for a few hours now back again. Off to dealer for me.
Old May 19, 2011 | 09:36 PM
Silver C's Avatar
C240
Try re-sync it.
Old May 20, 2011 | 10:07 AM
johnand's Avatar
Super Moderator
The manual re-sync that is described in the manual rarely works, and if it does, it only lasts for a short while. Re-sync via STAR works and lasts a long time if you keep the tracks and seals cleaned and lubricated. Since re-syncing and setting a higher current limit on mine over a year ago, and it still works perfectly.
Old May 20, 2011 | 11:25 AM
Norwichdelta06's Avatar
2007 c230
I agree I have to resync mine every month maybe?? But Im not goin to go to MB and pay to have it professionally? done? Maybe next oil change they will do it for free?
Old May 22, 2011 | 02:56 PM
hellsbells's Avatar
2007 C230 Sport
Thanks guys
I will try the manual resync. What is the STAR resync?
Old May 23, 2011 | 07:24 AM
Well, looks like its fine again. The [non MB] dealer sprayed some Wurth saBesto HSS 2000 to lubricate the sliders and its works a treat again. I asked him if its safe to put whatever this stuff is on rubber and if it will rust/damage the area. He says its all good. See how it goes from here.
Old May 23, 2011 | 12:56 PM
moonrkr23's Avatar
2013 c63 amg
clean n lube, had to have my g/f s 07 c230 done, was doing the same thing, works correct now
