2005 MB C230 Kompressor sport headlamp washer help!?
Old May 24, 2011 | 04:45 PM
Pkott716's Avatar
last week i purchased a beautiful MB c230, its the best car ive ever driven ( i cant imagine what the higher classes are like) but anyways, theres a button on the dash that looks like a headlight washer, when i press it, it makes a sound like it should be spraying, but its not. is it a headlight washer? i know there are little plastic cutouts that flip out and spray the headlights on the E class, idk if this is the same or not it looks like it has a cutout but its only on one side (see picture), ive included refference pictures, what is this button? and how do i make it work?!
Thanks in advance!
this is an awesome forum btw.
Attached Thumbnails 2005 MB C230 Kompressor sport headlamp washer help!?-p5220120.gif   2005 MB C230 Kompressor sport headlamp washer help!?-p5220121.gif   2005 MB C230 Kompressor sport headlamp washer help!?-p5220122.gif   2005 MB C230 Kompressor sport headlamp washer help!?-p5220123.gif   2005 MB C230 Kompressor sport headlamp washer help!?-p5220124.gif
Old May 24, 2011 | 06:32 PM
samaritrey's Avatar
Super Moderator
THE C350
Two ideas one your car had headlight washers and they were removed/covered up with a bumper from a car without them. Bumpers with the holes are way more expensive then the ones without. Second the headlight switch went bad and someone replaced it with one from a car with washers.
So do you have any fluid leaking from the front of the car when you push the button because it should still leak the washer fluid out the bottom.
Is this a usa build car if so pm your vin and i can find out if your car has washers or not.
Old May 24, 2011 | 07:10 PM
Pkott716's Avatar
the vin is WDBRF40J75A736262 made in Germany is what the sticker on the door frame says, i also didnt see any fluid out the bottom (although its raining) but theres deffinatly a pump going somewhere!?
Old May 24, 2011 | 07:43 PM
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
I would suspect, with the switch and the BiXenon headlights that the car has had the front bumper replaced with one without headlight washers. Since you can hear it try to spray, it probably just has the tube from the pump plugged, since the wrong front bumper is on it. We will know for sure when someone looks on EPC.
The front washers should look like the picture below.
Old May 24, 2011 | 07:44 PM
samaritrey's Avatar
Super Moderator
THE C350
110A IMITATION LEATHER
212B OP. INSTRUCT. AND MAINT. BOOKLET-ENGL. FOR USA/CAN
221B SIGN COOLANT/REFUELING - ENGLISH
232 GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUENCY
244 SPORTS SEATS, FRONT
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
264 LICENSE PLATE ATTACHMENT AMERICA
265 LINES-NO.PLATE DISCONTINUED
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
284B AIRBAG LABEL - ENGLISH FOR USA
287 THROUGH-LOADING FEATURE
293 SIDEBAG IN REAR LEFT AND RIGHT
301 ASHTRAY PACKAGE
309 CUP HOLDER
30N STEUERCODE WERK SINDELFINGEN/GRAZ
345 RAIN SENSOR
387 MOBILE PRE.-INSTALLATION (MTUS) USA / CANADA
414 ELECTRIC TILT/SLIDE SUNROOF IN GLASS VERSION
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
486 SPORTS SUSPENSION
494 U.S. VERSION
524 PRODUCT PROT. F.PAINT - TRANSPORT VEH.PRESERVATION
531 COMAND APS
535 AUDIO 20 CD RADIO, USA
540 ROLLER BLIND, ELECTRIC, FOR REAR WINDOW
543 SUN VISOR WITH ADDITIONAL FUNCTION
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
573 CHILD SEAT MOUNTING, ISOFIX IN REAR
580 AIR CONDITIONER
600 HEADLAMPS - CLEANING EQUIPMENT
614 BI-XENON HEADLAMPS FOR RIGHT-HAND TRAFFIC
634 DELETION - FIRST AID KIT
636 DELETION - WARNING TRIANGLE
639 LA 5 SPOKE DESIGN 17" WITH MIXED TIRES
668 PRODUCT PROT.F.TRANSPORT VEH. W/ TIE-DOWN HOOKS
673 HIGH-CAPACITY BATTERY
So the car had bix at one time that is interesting. So as I figured earlier it was probably wrecked and then fixed as cheap as possible. Like I said the bumpers without cutouts are cheaper as well as aftermarket headlights are dirt cheap compared to real bix.
Old May 24, 2011 | 07:51 PM
MW_ATL's Avatar
Are those aftermarkets that look like BiX? I don't know them that well... Looking closer, I guess so. Good eye Trey!
Old May 24, 2011 | 08:09 PM
samaritrey's Avatar
Super Moderator
THE C350
Since i have them it sticks out right away when i see the aftermarket lights.
Old May 24, 2011 | 08:26 PM
Pkott716's Avatar
so if im getting this right the car had BiX headlights and a different bumper, was wrecked, then fixed with normal headlights and a cheaper bumper to save money. ?
way to go carfax for leaving that tidbit out
thanks guys for all your help!
Old May 24, 2011 | 08:29 PM
samaritrey's Avatar
Super Moderator
THE C350
That is what it looks like sorry about the bad news. But if everything works ok and you love the car who cares.
Old May 24, 2011 | 09:02 PM
Pkott716's Avatar
Yea, not a big deal, I LOVE this car.
Thanks for everything guys!
Old May 25, 2011 | 09:31 PM
MW_ATL's Avatar
And just think, when the mod bug bites you and you buy a pair of factory BiX's, all the auto-leveling equipment is there. Of course, then you will be wanting a bumper.....
Old Nov 6, 2017 | 06:57 PM
Joseph Bell's Avatar
05 c230
Thanks in advance!
ou dont have headlight washers
Old Nov 6, 2017 | 07:06 PM
05 c230
I need help. Can these things leak and give you low coolant
I need to kno if these leak coolamt
