Why is my C230K Sport Coupe Stalling?
Old May 31, 2003 | 11:31 PM
Brahman Bull's Avatar
2003 C230K Sport Coupe
Angry Why is my C230K Sport Coupe Stalling?
I need help! I was on my way home today and my C230K stalled out. Restarted it, had to give it gas just to get it to idle then stalled out again. This is a brand new car less than 2 months old. To make a long story short, had to call Benz Help, towed to the dealership and it underwent diagnostic testing. Even after 2 hours of testing they have no idea why it was stalling. Has anyone encountered this problem or am I the only one? If someone has some information it would be greatly appreciated.
Thanks!
Old Jun 1, 2003 | 07:00 AM
gmabm's Avatar
My Kompressor did stalled once in the garage after a hard drive, I guess the confined area could be too hot n stuffy already.
Where did u experienced this incident?
Old Jun 1, 2003 | 12:58 PM
JeT's Avatar
JeT
A few members have had their cars inexplicably stall on them but then never happen again. You could probably do a search to find the threads...I don't think there was any real reason uncovered.
Old Jun 1, 2003 | 03:13 PM
kineda's Avatar
BANNED FOR VIOLATING TOU
C230k
There is an ongoing thread on csportcoupe about this:
http://www.csportcoupe.com/forums/sh...ghlight=engine
Old Jun 1, 2003 | 03:31 PM
schwarz c230's Avatar
C- 230 Kompressor,C2,C7,Black,JL sub,A/D/S/ amps,Alpine hu and changer
you might want to try a fuel system additive, and see if you have the problem on the next tank of gas, maybe you have some bad fuel
Old Jun 1, 2003 | 05:23 PM
BenzC240's Avatar
C240 02
Yep, this is what i was talking about in my other threads. Issues that existed on the previous models but have not been fixed on the new models. Shame on Benz. Look, first im sorry that u r going thru the same crap i went thru. Second yes this is an on going issues with some cars. Some people think they know what the fix is, some sepeculate and some it never happend again. I never had this issue happen to me as far as stalling. My issue was my car would not start and they had to replace the ignition system. By the way my car was towed too and it was only 3 weeks old. I personaly have no idea. Only advise i can give is make sure u r putting the right type of fuel, make sure the octane is correct. Good luck
Old Jun 2, 2003 | 02:23 AM
Thanks for the replies guys! I went ahead and did a search and found that most of the threads were inconclusive.
gmabm - as far as the where the incident occured it was in the city just after I got home from an approx 100 mile trip. I was traveling to my parents house and it just died while making a left hand turn.
I guess I will find out (maybe...you know service depts) tomorrow. But if they cannot find or fix the problem they are taking the car back b/c how can I feel safe if the engine cuts out on the highway let alone a city street like some have experienced in previous posts.
THX again guys!
Old Jun 3, 2003 | 07:08 PM
dontwakemeup's Avatar
C230K Coupe
Since I had the exact same scenario (only two months old and nothing returned from diagnostics), I thought it might make you feel better to mention that it has never happened again--going on 23000 miles and year later.
Leads one to speculate... ????
Let's just hope that this will be the case for you as well!!
Old Jun 3, 2003 | 08:14 PM
BenzC240's Avatar
C240 02
brahman i would not settle for just "it never happend again" or "can not duplicate it" like u said this is a serious issue and u can get seriously injured at the best in case it stalled in an intersection
Old Jun 4, 2003 | 10:10 AM
C230K Coupe
Yes, you shouldn't have to settle for just hoping it doesn't happen again. It HAS to be an issue that MB is more than aware of. However, it is my impression that there are NO explanations for a non-recurring stall problem and that the most common "cure" for a recurring stall problem is to replace the fuel pump--but that should have been found during the diagnostics. There could be a sleugh of different causes for a one time stall problem--perhaps bad gas, vapor lock, temporary sensor malfunction...? Just sharing in my own experience--I couldn't reproduce it, sorry I'm no help.
Old Jun 5, 2003 | 08:19 PM
ChicagoC's Avatar
C230
Transmission Control Module
I had a similar problem - car stalled without warning at highway speed. It sat for an hour or so, then started right up again. Never happened again.
One dealer could not diagnose any problems. But another dealer diagnosed a faulty transmission control module, replaced it under warranty, and it's been fine. They explained it as a sensor that shuts the engine down if it detects that the transmission is doing something that could cause damage to the motor - sorry for my lack of technical expertise on this. Since the sensor was faulty, it was giving incorrect readings and shut the engine down. Most likely a short of some kind. Hope this helps.
Old Jun 5, 2003 | 08:50 PM
rrf's Avatar
rrf
Thank you ChicagoC
Old Jun 5, 2003 | 08:58 PM
jpb5151's Avatar
Hi, ChicagoC. Hope you enjoy the forums.
Old Jun 9, 2003 | 01:30 AM
puffed's Avatar
c230k
my 2003 c230k had a problem with the engine dying
while going straight, just pressing gas lightly about 25mph
then bang the whole car dies, all idiot lights come on and
you have to restart the whole car to get going.
During this one trip the car died four times in about five minute
spans each time.
they finally trouble shot to defective
throttle actuator/throttle body
part number is 1 271-141-00-25 slide
