Rain wipe sensor playing up :-(
I dont think this is related, but it started happening around the time the wiper fluid refill message came up.
Its not a big deal because I can turn it off, but maybe there is a quick way to reset?
Maybe someone who has STAR can play with it and let us know?
Factors to consider. LED's have a finite life. The light is not visible to the naked eye, but you can see if they are all on if you point any electronic camera at them, cell phone, video camera, or digital camera. If one or more are out, you need to replace the windscreen because in the workshop it is almost impossible to attach the assembly to the glass properly. The assembly might have delaminated from the glass, and this requires a replacement.
There is a sensitivity adjustment through STAR diagnostics because the sensitivity of the photodiodes varies over a wide range.
It is possible that car care products are causing undesired operation. Any thin film coating on the glass can cause the infrared light to be refracted into space. Products that are emulsion based, or containing silicone can cause this. There are solvents that can remove most anything, but the easiest way is to use an abrasive cleaner that will not harm the glass. Bon-Ami is the choice of most professionals to really clean the glass. It is a kitchen sink cleanser, a white powder but different from most because the polishing agent is egg shells and will not scratch the glass. (Don't use other kitchen cleansers, they will muff the glass.) You don't need to clean the entire glass surface, just around the sensors. If you have streaking or skipping of the wipers, Bon-Ami will fix it too.
Could the heat be causing it? Here in Australia have have had very hot days recently and it so happens that it this started when the summer hit.
If you can find someone with STAR diagnostics you might try an adjustment of the sensitivity.
Rain-x allows me to drive at highway speeds without the wipers on. Saves on fuel because the pads are not feathering the discs .
I wish I could cancel this feature as it not req in warm climates..
BMW issued a bulletin in the ‘90s (#61 02 94 3990) recommending its use to cure chattering wipers owing to windscreen contaminates.
My stash of GM’s PN 1050011 “Windshield Cleaner Powder” is actually cleverly repackaged Bon Ami.
No clue if it’ll solve anonymousmoose’s rain sensor woes, though Faultless’ blend is an oft-proven consumable around most every workshop and household.
http://www.bonami.com/index.php/prod...wder_cleanser/
Cleaning with Coke sounds pretty interesting. Makes you think twice about drinking the stuff.
Obviously you wash with water after that. Movie was worried about goo'ing things up with US Coke because it contains corn syrup & not cane sugar. Very old discussion we had.
