no fuel delivery 01 c320
I checked for fuel in the rail, and find that it is dry. I checked the fuse... good, and replaced the relay... still no fuel to the rail.
After turning switch to position 2, I can hear the fuel pump run for several seconds and then stop. Shouldn't the pump run until it reaches pressure?? I get no fuel to engine no matter how many times I switch it on. I've also tried a little gas down throttle body which makes the engine run until the gas is gone... still no fuel delivery.
I pulled pump out and cleaned pickup screen. While out, I bench tested pump in pan of gas and it flowed (but I didn't verify pressure).
Am I missing something? Any thoughts??
By powering the pump directly, I get 48psi... less than spec, but pressure. I can start the engine, and the pressure drops to zero. The pump doesn't run under operational conditions.
I hear the pump run for a few seconds at switch on. Does anyone know if the pressure sensor at the driver side in-tank unit would stop the pump if it thought it had pressure... and if that could be the problem, how it could be checked??
Safety first when checking electrical equipment near fuel fumes .
See 125
125 A 163 542 28 18 .PRESSURE SENSOR AT TANK
This should be correct for your early car. On newer vehicles it was integrated into on of the fuel level sensors.
I had to print the four wiring sheets out to see them (which I just got done), and some stuff is still a little fuzzy to read. Is this the wiring specific to the fuel pump?
I have looked at the B4/7 connector, but wasn't sure how to test it.
The diagram that Glyn posted does look exactly like my setup. One question though...it shows sensor 125 out on it's own. It sorta loks like they are made together on my car. Is that a diaphram type sensor??
Durhamite,
Regarding B4/7
"PU/PI/PIZ Differential Pressure Transmitters
This group of differential transmitters are designed for general applications. The PU gives a Voltage output. The PI has a current output and the PIZ is a 2 wire 4-20mA device. All versions have the option of a digital display."
So you should be able to check its operation with a voltage meter.
N118 the intank fuel pump control module could also be a source of the problem .
So the questions I would ask myself , is the Pressure Sensor B4/7 speaking correctly to the N118 fuel P/P control module & is the N118 control module speaking with fork tongue with the in tank fuel pump?.
You will have to sit down with your voltage meter & nut it all out !!
Check at the bottom of the page ,left hand side for engine types relevent to drawing.
Let us know how you go.
http://www.halstrup-walcher.com/Deta...mformer&ID=130
Cool... I guess I gotta simulate some pressure to the sensor, and see what it does to voltage
Unfortunately, I had to leave my car about an hour from me (safe location) and I can't just step out and try something, so I have to hit and run as I can. I looked at the sensor today, and it looks like it is bonded with the level sender unit... this the case??
At this point, I would replace the sensor if I can get it.
Once again, I really appreciate your willingness to help.
I know on some cars you have to buy the whole tank sensor unit. I was hoping yours would not require that.
I am particularly interested in components/sensors which control the fuel pump relay which is fitted on rear SAM.
On another forum I read that when the engine is not running a sensor switches off the fuel pump. Any ideas which sensor that might be? Also someone had found a burnt pin to a connector on rear SAM which made the relay intermittent and hence the pump operation.
The diagrams already published on this page are too small to read. Any help would be much appreciated. Thanks in advance.
Schematic diagrams are much better for fault finding and understanding how the system works. I can never get hold of these for Mercs.
