Evooolution of my 2006 C350 6spd!
if you want a deeper sound you can probably see if anyone's selling the c32 muffler for cheap.
otherwise, i don't think you can get a quality exhaust that doesn't drone. Remus is nice and cheap at around $400-450, but they do drone. maybe a universal Borla exhaust would be nice. someone has it on the forum recently, but forgot who it is.
Do you have any other mods in mind?
If you have the time, money, patience and support I would skip all the header/82mmTB/manifold and go straight for a low boost turbo build.
If you do a little research on turbo forums I'm sure you can build yourself a pretty decent kit.
When I look back I don't think I'm pretty satisfied with my results and I wish I never went this route.
For my headers my steering shaft still rubs on the driver side header on mid engine load. After I did the TB/Manifold mod I did gain great power up top but I also lost power down low. My power band is ok but my tune is ****. Down low I don't have good power till about 2.8k then from then on it's a beast but my tune is off whack and my car shuts off and throws ESP error code. I heard around the forum this was a tuning issue. I use to have it before the TB/Manifold combo and it got eliminated but after I put it on I get it back. It's mostly when I am at the peak power band. I still don't know if this is a torque limiter issue or if the tune is aggressive/pinging and engine shuts off. So now I'm stuck with power at 2.8k and I have to run through the whole gear. So If I want to go at it with a car I cant hold the gear at the peak power because my pedal will die. I know Cale was getting this issue as well and so did some other members with other tuners.
But when I originally got my tune the car was running like a champ. Then I got these errors. Went for a retune and it was ok got it once in a while. Went for a retune for the tb/mani and now the same.
What I'm trying to say is make sure whichever route you go it's proven.
http://www.ebay.com/itm/OBX-Header-M...ht_3020wt_1396
http://www.ebay.com/itm/OBX-Exhaust-...item2c633d231d
Your WHAT?
