transmission
Old 02-07-2012, 08:34 AM
  #76
Norwichdelta06's Avatar
2007 c230
Originally Posted by Glyn M Ruck
Yes.
perfect hopefully its fixed. 1000 thousand for 3 things i guess isnt that bad.
Old 02-07-2012, 08:53 AM
  #77
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Are you saying $1000 to reset adaptations?
Old 02-07-2012, 09:36 AM
  #78
2007 c230
CPS SENSOR.. i could've done it myself but I was having problems starting my car and I didnt want to get stuck in the city and end up paying a tow. And also a magnet on the cam needed to be changed. He only charged me an hour labor even though its a few minute job I just said for him to go for it. Plus oil change
but the best part was that he said he needed to do service B before trying the transmission adapation thing.
Old 02-07-2012, 09:52 AM
  #79
LILBENZ230's Avatar
That last part - that they need to do Service B before trying the adaptations - is so much BS. You let them do that to you?
Old 02-07-2012, 10:19 AM
  #80
2007 c230
nope haha.. but i can understand how other people would fall for it. he made it sound like an ultimatum. the best part was that I didnt respond to him and left him in silence then he answered the question himself
Old 05-14-2012, 10:51 AM
  #81
dbrowninvest's Avatar
07 c230
Originally Posted by SickSpeedMonte
Add me to the list too... if someone is putting together a class action. 81k miles on mine, bad conductor plate/turbine speed sensor. Same exact symptomes and service was done at 39k miles.
MB dealer has my 07 C230 now with same issues at 45k - quote of $1200.
Old 05-14-2012, 06:56 PM
  #82
04mbc230's Avatar
2006 C230 Sedan
Uhh.. you might get lucky, your warranty is set to expire this year, but that depend when the car was purchase.
Best of luck, if warranty covers, then you don't have to fork the dough for this grave piece of $#%% they put on the car.
Old 05-15-2012, 10:34 AM
  #83
LILBENZ230's Avatar
07 warranties should have expired in calender year 2011.. unless you bought an 07 new in mid-08.
Old 05-15-2012, 11:23 AM
  #84
Super Moderator
Glyn M Ruck's Avatar
You should try & reset adaptions with relatively new fluid.
Old 05-15-2012, 06:26 PM
  #85
04mbc230's Avatar
2006 C230 Sedan
Although true, but I known of a 07 that had it's warranty just expired on Apr this year.
Old 06-06-2012, 03:09 PM
  #86
jrtor's Avatar
gl 320 cdi
Just got this from the service advisor gl320 2007 g7 out of warranty 49000 mile. Seem like alot of people having this problem
Ok Faults stored and current for gear requested implausible, dropped pan and fluid is good and filter and magnets are clean of any metal or debris. $278.00 DONE
Needs transmission shift conductor plate, need to drop valve body and replace and reprogram shift adoptions after with new filter and filter $1346.00-15%(-201.92) =$1144.08
3-4 days special order to get that part needed installed and your truck back on the road safely. Please let me know how to proceed, best regards, Dustin
Old 06-06-2012, 03:52 PM
  #87
SamirD's Avatar
My mom's 2007 c280 may have a similar issue, but I'm not totally sure.
When dropping them off to the airport in a hurry, the car was shifting so hard it was actually barking the tires all the way up to 3rd gear. I noticed that the indicator next to the gear on the instrument cluster had a small square vs a 'c' or 's' for sport/comfort mode.
I could start and re-start the car a couple of times and maybe it would show it, but it would go back to the square while driving. If I wasn't hard on the gas, it would shift fairly normally. I could still detect that it was a hair harder than normal, but I help maintain our fleet of 13 cars, so I'm not your average bear. My parents wouldn't have noticed.
My father mentioned that prior to this, he couldn't get the car to shift out of park. After this trip to the car will not shift out of park. The shifter moves, the shifter indicator shows the correct gear, but the instrument cluster doesn't show it shifting.
Thoughts?
Any assistance appreciated. (Even if it is a link to a better thread for my issue).
Old 06-07-2012, 12:38 AM
  #88
FatFatW203's Avatar
2006 Mercedes Benz C280, 2005 Mercedes Benz C240
How Much Is A Transmission Flush At The MB Dealership?
Old 06-07-2012, 10:14 AM
  #89
LILBENZ230's Avatar
Thoughts?
Hook it up to a computer and see if you're getting pending codes. Do you have the 4Matic or RWD?
Old 06-07-2012, 10:15 AM
  #90
LILBENZ230's Avatar
The dealers here all say they don't flush the transmission.
Old 06-08-2012, 10:49 PM
  #91
SamirD's Avatar
I have a friend with a code reading, but haven't gotten the time to get him to the car. What codes should I be looking for? It is a rwd.
Old 06-09-2012, 05:01 PM
  #92
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
Ha, yeah. Which is why it's pretty much necessary to do it yourself.
But what a pain on the 7 speed.
Old 12-15-2012, 02:11 AM
  #93
SteveL1's Avatar
'16 SL550, '18 Porsche Macan GTS
I'm having similar symptoms but mine is an '06 with the 6 speed. Will stick in high at a stop sign or not up shift from 1st or 2nd gear. Does not happen all the time and will re set if turned off briefly. Car has 112,000 miles on it and has not had the fluid changed in quite a while. No CEL lights or codes.
Could this be a similar problem to what the '07s are experiencing?
Old 12-15-2012, 09:25 AM
  #94
tasmit99's Avatar
2007 C280 luxury
From experience having the conductor plate replaced on my 7G tranny. The reason for dealer doing it is reprograming. I don't think an indie shop is capable of doing and they could really mess things up by doing it wrong. IMHO
Quick Reply: transmission
