W203 Anti-theft control module
I think my Anti-Theft module is not working. The red flashing light in the cabin doesn't start when I engage the remote lock. I used this thread to locate the module. Found exactly what techniker describes (with the 3 wires). However, in my car the part number is different. Do part numbers vary even within w203s? My part number is A203 820 27 26. I just wanted to know if techniker's mentioned part number is compatible with my car.
Also, from what you have read, am I going in the right direction? I tried replacing the siren (that sits behind the F/R mud guard) but that didn't help. I have attached a picture of the module below.
I replaced the siren because that's what someone said the problem was. But I returned it to the seller for a full refund, so no harm done.
Secondly, I don't trust those guys with the scanner because I had a problem with my F/R turn signal, and two mechanics used their equipment to suggest that there was no ground and hence the control module for the turn signal had to be replaced. I didn't believe them so I got to work on it myself and found a bad contact between the the bulb and housing--that's all!
