Is there a way to check timing chain with tearing engine apart?
Old Mar 11, 2012 | 09:07 PM
Hogger's Avatar
2009 ML350, 2007 GL450, 1963 GMC, BMW 325i
Trying to figure out options.
After seeing the piston pictures, do you think there could be damage to the connecting rods?
Do the pistons need to be replaced?
I read that if the dented area of the piston doesn't hit the cylinder wall, that it would be OK.
I'm thinking I'll pull the head, and weight the cost of buying a remanufactured head, or having mine worked on.
What other engines are compatible with this car, with a 6 spd. manual? I know it won't be a plug and play, but something that won't require moving engine mounts, etc...
Old Mar 11, 2012 | 10:07 PM
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by splinter
Yep! ambit's DIY is a help but no torque specs. order of work or tensioning chains etc.
Old Mar 11, 2012 | 10:16 PM
Super Moderator
OK - we know you have to pull the head. Let's make a decision once it's off and we can see things properly. From the pics I don't see any dents bad enough to condemn the pistons but the pics are not clear. Minor dings in the valve pockets can be cleaned up with a Dremmel.
I would not attempt to fit another type of Benz engine. To many expensive issues to address.
Old Mar 11, 2012 | 10:26 PM
Hogger's Avatar
Thanks for keeping up with this.
I'll get started on the head, and post up here what I find. Might be a couple days or so, depending on work.
Old Mar 12, 2012 | 09:35 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
What kind of rattle were you hearing on start up? Loud? Metallic? Soft rattling? For just a second or longer?
Old Mar 12, 2012 | 10:18 AM
Super Moderator
Matt - if you ever hear a minor rattle of the chain against the chain case on cold startup that shuts up the minute the oil pressure comes up it's time to consider having a new chain pulled through long before the chain gets loose enough to jump. You need to listen with the drivers door open. You can seldom hear it with the doors closed until it's too late.
Old Mar 12, 2012 | 10:24 AM
  #32
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
yea 2005s still have the chain issue...
ya matt i get that same noise...im at 60k miles lol
a new chain at 60k?
hey glen if i get my chain replaced do i get everything else to? (guides and that other chain u were talking about)
Old Mar 12, 2012 | 10:47 AM
  #33
Super Moderator
No - you can just pull a new chain through as per WIS instruction I posted earlier in this thread.
Old Mar 12, 2012 | 11:36 AM
  #34
LILBENZ230's Avatar
I don't have any noise, I was just asking what exactly to look for. If it shuts up as soon as oil pressure comes up it must be very brief. I just don't know what exactly to listen for. Wish someone had a recording of the noise. Anyway, my car doesn't seem to make any strange noises during start for now. I just like to be informed and on top of things.
Old Mar 12, 2012 | 11:41 AM
  #35
Super Moderator
Good!
EDIT. It's such a cheap job to pull a new chain & fit a new tensioner compared with fixing the mess caused by a jumped chain.
Old Mar 12, 2012 | 02:03 PM
  #36
Hogger's Avatar
I had a decent recording of it. But I just updated my iPhone and it restored back to December. So I lost everything in between. Don't update over wifi. Plug into iTunes.
I was getting rough starts when it was cold, like it was missing. Then it would smooth out after about 10 seconds. And the rattles, that would last just a second or two.
Old Mar 12, 2012 | 03:54 PM
  #37
LILBENZ230's Avatar
At least there are typically warning signs. Mine is all smooth, no rattles @ 131.5k.
Keep us updated.
Old Mar 12, 2012 | 04:38 PM
  #38
Keep us updated.
its more of a constant ticking sound coming striaght from the cam box
i'd make a vid but it only does it on the first start of the day
Old Mar 12, 2012 | 04:43 PM
  #39
LILBENZ230's Avatar
Make a vid.. it should go away immediately once oil pressure comes up. I'm not sure you have a timing chain issue at all.
Old Mar 12, 2012 | 05:48 PM
  #40
Super Moderator
Constant ticking sounds coming from the cambox are hydraulic lifters & have nothing to do with chains. Stop posting crap.
Chain rattle comes from the chaincase between the crank & head. It is not constant or you would be in big trouble.
Old Mar 12, 2012 | 07:33 PM
  #41
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Unhappy
Hi Glyn, I was checking on mine today, and there is some metallic sound but seems like it's coming from exhaust manifold.
How long in time does it rattle before the oil level comes up? Mine seemed to do on for 10 seconds before I turned it off.
Also, I opened the oil cap with the engine running - to listen - and air was blowing from there (not too hard, as I was able to put the cap back on with no effort).
Is it normal, or my gasket is worn @ 118k mi?
Old Mar 12, 2012 | 08:44 PM
  #42
Hogger's Avatar
Your oil level should be up in a second or two. That's how long mine "rattled" before the pressure was up.
Old Mar 13, 2012 | 07:46 AM
  #43
Super Moderator
+1 - this is the symptom one must be listening for after the car has stood for a long while or overnight
VVF - it is normal to have blowby from the oil filler cap. This is a captive breathing engine.
Old Mar 13, 2012 | 09:18 AM
  #44
my bad for not being more specific... constant ticking for a min then it goes away
Old Mar 13, 2012 | 09:35 AM
  #45
LILBENZ230's Avatar
Can you make a video? I don't think ticking is indicative of the chain. I've been trying to understand the noise, too, but if you think about a stretched chain rattle.. you can almost imagine it. Plus it would be brief, the oil pressure comes up quick.
Old Mar 13, 2012 | 09:55 AM
  #46
Super Moderator
Matt - just imagine a brief Grrrrrrrrrt of a chain slapping against an aluminium housing. Aluminium actally amplifies this sort of noise whereas steel does not.
Old Mar 13, 2012 | 03:59 PM
  #47
Hogger's Avatar
Here's where I left off last night. Hoping to have the head off today.
Anyone know the unbolting sequence for the cam cage thing(sorry, not exactly sure what to call it), and the head unbolting sequence?
Got some great info from mikey1011 on the other post. Along with some of the DIY's.
Glyn, I'm going to replace the balancing chain, would you suggest also replacing the guides for the balancing chain?
Is there a way to check timing chain with tearing engine apart?-d2c7017e.jpg
Old Mar 13, 2012 | 04:27 PM
  #48
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
I recall that FIAT put grooves on it's 1500cc engine pistons used in such cars as the X19 (which I owned) so that JUST IN CASE the belt snapped, the valves would not impact the pistons. This after it happened many times in the earlier 1300cc.
You were supposed to replace it every 30K miles. I did mine religiously, once I learned how to do it.
Of course, Mercedes would never want to admit such a thing could happen, and therefore of course would never bother to build something like that in. something a lowly company like FIAT used way back in the 1970's.
Sorry to see your troubles.
You seem to be on the right track!
You didn't purchase the service DVD?
Old Mar 13, 2012 | 04:54 PM
  #49
Super Moderator
Examine carefully - if there is wear or any sign of cracking replace them. You don't want to do this again.
PM Johnand or splinter & ask them to post the R&R. I don't have torque specs, order of undoing/torquing etc. You really need that.
Old Mar 13, 2012 | 04:57 PM
  #50
Super Moderator
Yep - Today no one builds non interference engines with modern power demands.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
