Fog Light wiring help
Old Mar 22, 2012 | 12:43 PM
DustinH's Avatar
c203
I have a 2006 c230 sport and have a problem with the fog lights. I have looked everywhere but can't find the wiring to hook up to the drivers side fog light, the passenger light works just fine. I bought the car used a month ago and thought the bulb was all that needed replacing.
Any help with where to look for where the wiring harness should hook in would be greatly appreciated
Old Mar 22, 2012 | 02:16 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Hmmm, wish I remembered, but it's been years since I switched out my foglight bulbs. What I would do is remove the belly pans and trace the wiring from the passenger's side as far back as possible, and try to recreate that same path on the other side.
You might be very unlucky and have had a shady owner who removed the harness completely to try to "fix" the warning light. I'm assuming you get the bulb out warning?
Old Mar 22, 2012 | 05:58 PM
samaritrey's Avatar
Super Moderator
THE C350
I think it goes around the outside of the fluid tank and then into that mess with all the other wires for the pump.
Old Mar 23, 2012 | 02:13 PM
DustinH's Avatar
c203
Thank you for the advice, I have already removed the pan while I had it on a hoist and attempted to locate it by looking in the same place as the passenger side. No luck though.
I will take a look around the fluid tank and see if I have any better luck there.
So far, I have looked just about everywhere and have no loose ends hanging around and am stumped.
I appreciate the help
Old Mar 23, 2012 | 02:17 PM
tommy's Avatar
In that case, what I would do is have your local parts department pull up the scematic that includes the wiring of the driver's side fog light, and then have them print it out. Or talk to you SA at the dealership, if you've got a good renationship with them.
I'll be swapping out my winter rims for my summers this weekend, and pull down my belly pans, and see if I can take some pics, or at least describe the layout of where the wiring goes.
Old Mar 26, 2012 | 12:04 PM
tommy's Avatar
OK, finally swapped out my tires yesterday, and from what I see, the wiring for the fogs (on each side) joins up with the other electrical wiring about 12" from the front corner in the engine bay. If you see no wiring at all for the driver's side fog, they must have clipped it just south of that juncture - you'd have to cut the shrink wrap and see if it continues, or if they have completely removed the wiring.
Old Mar 27, 2012 | 06:28 PM
Wont Pass Me's Avatar
05 C320K, 99 BMW M3
This is alomst creepy how close to my story this is. I too would like to know where the harness ties in. pics? anyone have any luck?
Old Mar 27, 2012 | 06:49 PM
phister's Avatar
06 C230 SS 6spd
it wraps around the wiper fluid tank and connects to a larger set of wires.
Old Mar 27, 2012 | 07:04 PM
05 C320K, 99 BMW M3
Thanks fellow funkytowner
tommy's Avatar
I wish I'd said that.
Old Mar 27, 2012 | 07:47 PM
05 C320K, 99 BMW M3
touche, I read your post but was hoping for a pic. Either way thanks. Now would anyone know where i could get a new connector?
Old Mar 27, 2012 | 07:53 PM
phister's Avatar
06 C230 SS 6spd
Dealer or auto store should carry it. Might ask them since it will probably kept in the back.
Old Mar 27, 2012 | 08:15 PM
tommy's Avatar
As I said to Dustin, the best thing you could do would be to get the scematic from the parts dept of your local dealership - that could help you with the wiring. I think it would be pretty hard to do on your own without the wiring diagrams, though.
If you look at the bigass wiring bundle running up the outside of the engine bay on each side, the foglight wiring is included in that group (normally).
Old Mar 29, 2012 | 01:57 PM
DustinH's Avatar
c203
Thank you for all of the suggestions. At this point, I have followed all of the wires along the drivers side front panel near the washer tank with no luck. I will have to head to the dealer, hat in hand, and ask for a schematic because I can't find anything that has been clipped or a stray end dangling.
I am at a total loss for how or why it would have disappeared but that is the risk you take when buying a used car right?
Old Mar 29, 2012 | 02:07 PM
tommy's Avatar
On the other hand, if a foglight wire being missing is the worst thing, you're doing pretty well. Good luck.
Old Aug 11, 2015 | 05:31 PM
Moedy's Avatar
'05 CLK55, '04 CLK320
Any luck with this? My fog light wiring was hanging out the bottom of my car while driving and got yanked out
Old Jun 26, 2018 | 12:29 AM
Husam Haopsh's Avatar
2008 X164 GL550 & 2015 W166 ML350
I think the same thing just happened to my C280 2006, did you manage to fix it? Where and what part did you get?
Old Jun 26, 2018 | 12:31 AM
Where to get the fog light harness? And how does it connect to the rest of the wiring?
Old Feb 9, 2019 | 11:01 AM
Skorp's Avatar
2005 Mercedes Benz CLK 500; 2007 CLK 63 AMG; 2014 E350; 13 Porsche Boxster
I have the same issue. I took my car to a certified Mercedes dealership to get it check out in 2017 and then I get it back and the left fog light cable is completely gone. Now, I always get left fog light out. Not sure what to do as they have no idea what happened. All I know is I had it there before and after getting my car it is gone. Tired of driving for over year with that message appearing all the time. Is there at least a way to disable the left fog light message?
Old Oct 16, 2021 | 07:30 AM
jocaho's Avatar
2007 230 sport
Same for me no fog light wire harness I did notice a ground wired bu Floyd holder that was jus screwed down but looked ripped off and my fog light is fill half way with water it’s like the harness just disappeared guess I’ll check driver side and jet y’all know
Old Oct 26, 2021 | 04:56 PM
angelusnhc's Avatar
07 mercedes benz c230 sport
i have the same issue. my driver side never worked so i changed out the bulb. as doing that i found there is no connection harness or wires anywhere to be found on the driver side.
