c230 kompressor stopped running just make clicking noise???
Old Jun 10, 2012 | 01:50 PM
andrewone222's Avatar
2004 mercedes c230 kompressor
Hello, I have a c230 kompressor that started up rough a day ago and the third time it would not start. It makes a fast qlicking noise when i try to turn it over however nothing will start now? Is that my timeing chain? if so is this car a zero tollerance engine and could it be blown now? just got an oil change a week ago.... They did add too much oil, so I took some out and the front smark plug I had to clean off becuase it had oil on it. nothing still will run?
Old Jun 10, 2012 | 02:38 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Check the battery voltage (12V+ ?). Clean the contacts, bang on the starter with a piece of pipe or metal. Then try.
Old Jun 10, 2012 | 02:47 PM
u see the battery looks bran new, no corrotion at all and everything is tight. All lights and wondows ect work strong... Im getting spark, the engine is cranking a bit but just not fireing up???
Old Jun 10, 2012 | 04:15 PM
phister's Avatar
06 C230 SS 6spd
might be the starter or alternator. you can remove them and have an auto store test them for free
Old Jun 11, 2012 | 10:33 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Based on the description of the "rough start".. I'm suspect of the timing chain personally. Though the clicking could indicate a bad battery. How many miles are you at?
Old Jun 11, 2012 | 09:57 PM
Ask a crappy question, get a crappy answer.
Old Jun 12, 2012 | 12:14 PM
Hogger's Avatar
2009 ML350, 2007 GL450, 1963 GMC, BMW 325i
That's what mine did. Had rough cold starts for a few days. Then I went to go to work one day, and it made a loud clanking sound on start up. I stopped turning it over, and tried it again, when it only clicked.
I think there is some kind of safety system built in, that does that where there is too much resistance to start it.
I had the battery, and starter checked, and they were fine. That led me on my timing chain adventure.
How many miles on your car?
Has your car been making a rattling sound on start up, for a few seconds?
May still want to have the batt and starter checked. But I don't know what's worse, pulling the starter, or pulling the valve cover to check the timing chain............ Probably pulling and replacing the starter.... What a pain that was.
What do you mean it cranks "a bit"? Could be battery.
Old Jun 12, 2012 | 03:50 PM
Glyn M Ruck's Avatar
Super Moderator
Check fuse 52 - it might have blown & needs to be elevated from 15 to 20 amps.
