Valve cover gasket leak? w203 Pics *
Could you get us a picture of under the air cleaner on both sides.
On my car the plastic got old and brittle and just started to come off on its own. You just need some heat resistant plastic/rubber cover to keep it from chafing.
Please advise that you also purchase the 3 PVC (purge Valve control) tubes as mine all tore apart when you have to remove them to get the valve covers off.
Spark plugs were easy! I used the 17 mm. spanning wrench and got the wires off JUST PRIOR TO PULLING THE VALVE COVERS OFF!
New Bosch 4 spark spark plugs ROCK!
For 18 bucks, I will fix it.
You don't need a DIY on the valve covers. Pull off the aircleaner. Everything is exposed. Remove valve covers & clean them up. Fit new gaskets & reinstall.
I recommend you use a thin coating of Yamabond 5 or 6 on those damn gaskets as they frequently weep.
Good luck!
